Old 03-31-2017, 01:46 PM   #1
Kitfox5
Default Brake lines
My 1950 F1 came to me without brake lines. The brass block on the master cylinder where the stop light switch goes has 3 openings. Where do the right, left & rear lines go in this block? Thanks you
Kitfox5 is offline   Reply With Quote
Old 03-31-2017, 01:50 PM   #2
flathead48
Default Re: Brake lines
It should be the same as my 48, one in rear is stop light switch, Rt side for Lind feeding rear brakes and left side to feed front brakes. Hope this helps
flathead48 is offline   Reply With Quote
Old 04-02-2017, 04:27 PM   #3
Kitfox5
Thanks flathead48
