Old 03-31-2017, 10:49 AM   #1
firerod
Default Help with speedometer gear
Anyone out there have a Ford speedometer gear chart that could help me pick the right size gear? I have 700x16 rear tires (approx. 30.4" diameter) and 3:78 ring and pinion.
firerod is offline   Reply With Quote
Old 03-31-2017, 11:16 AM   #2
alanwoodieman
Default Re: Help with speedometer gear
19 tooth is for 3:78 with 29 1/2" tires 6:/6:50 by 16 tires. 18 tooth is for 3:54 gears, 21 is for 4:11 gears
alanwoodieman is offline   Reply With Quote
Old 03-31-2017, 11:17 AM   #3
deuce lover
deuce lover's Avatar
Your choice is either 18 or 19 tooth.Given your tire size I would try the 18.
deuce lover is offline   Reply With Quote
Old 04-01-2017, 11:10 AM   #4
firerod
Thanks guys.
Old 04-01-2017, 11:51 AM   #5
JSeery
JSeery's Avatar
There are charts in the Green Book, pg 632-634 in my book.
Old 04-01-2017, 12:16 PM   #6
JM 35 Sedan
JM 35 Sedan's Avatar
I don't think you're going to nail it any closer than +/- 5 mph with any of the standard Ford speedo turtle gears available. I played around with 4.11 & 3.78 gears in my 35 fordor with 750 x 16's on the rear and could never seem to get any closer than +/- 5 mph.
John
Old 04-02-2017, 06:05 AM   #7
39portlander
39portlander's Avatar
I put an 18 in the 39 pickup as the rear end is now 3:54. I think I found that gear in one of the model A catalogs.
39portlander is offline   Reply With Quote
Old 04-03-2017, 03:00 PM   #8
firerod
I will try an 18. Thank you all.
