Old 03-29-2017, 04:49 PM   #1
wrndln
Default NOS Ford valve question
I recently bought some NOS Ford valves. Some have an indented top with the Ford script on them. Some have a smooth top with a Ford script on them. A couple have no script but look unused. The valve on the left is one I got at a swap meet, has IN on the top and looks new. Could this valve be used only for intake valves? I am wondering if these valves are good enough to use in engines with modern gas and its additives. Any input on these valves would be helpful. BTW, I am building a stock engine, nothing special.
Rusty Nelson
Old 03-29-2017, 05:44 PM   #2
1930artdeco
1930artdeco's Avatar
Default Re: NOS Ford valve question
I used NOS ford valves in my engine and it works just fine on pump gas.
Mike
1930 TownSedan (Briggs)
1957 Country Sedan
Old 03-29-2017, 06:08 PM   #3
wk2w
I've seen some older repair pictures that had all the valves with the circular recess like the one on the left in your picture. That may have made lapping easier, don't know. Haven't read anything that says there's a difference between the intake and exhaust valves.
Mine were all smooth top, but there's a very good chance they had been replaced.
Would be interested in other replies.
wk2w is offline   Reply With Quote
Old 03-29-2017, 06:16 PM   #4
Synchro909
Synchro909's Avatar
Years ago it used to be that intake and exhaust valves were made from different materials. Not knowing how old those valves are, I would use that one on the inlet. You have nothing to loose by doing so but maybe if you don't.
When all is said and done, more is said than done. That's why we judge people on what they do, not what they say.
I sometimes wonder what happened to the people who asked me for directions.
If I am not in trouble, I've done something wrong.
Old 03-29-2017, 06:25 PM   #5
ursus
I've seen Ford marked valves with the IN, X, and R. The IN and X valves were in the corresponding intake and exhaust positions and the "R: valves were scattered all over. I don't know what the "R" stands for.
ursus is offline   Reply With Quote
Old 03-29-2017, 08:55 PM   #6
Doug Clayton
Valves with Ford Script are all stainless steel and in my opinion are superior to anything made today. The flat top valves were the first design of the stainless type. In the mid-late 1930's, the as-forged, recessed type was introduced. They are the same alloy and can be mixed in an engine, however, I like to use them in sets (all the intake the same and all the exhaust the same). One important note: when using stainless valves, increase the clearance for the exhaust valves ONLY to .015-.017" due to increased thermal expansion.
Doug Clayton is offline   Reply With Quote
Old 03-29-2017, 08:57 PM   #7
barnstuf
When you manufacture several million engines the pennies saved on each add up, so when engines were new the valves were different in quality for intake and exhaust. As the cars aged it made sense in making valves for the replacement market to standardize so all are of exhaust quality, and are used for intake and exhaust.
barnstuf is offline   Reply With Quote
Old 03-29-2017, 09:31 PM   #8
WestCoast
indented valves are intake and can only be used in the intake valve seats, they are heat treaded differently than the exhaust valves, they will quickly burn if used for exhaust valves ,flat top valves are exhaust valves and can be used for either intake or exhaust
WestCoast is offline   Reply With Quote
Old 03-29-2017, 09:49 PM   #9
Doug Clayton
Indented FORD script valves are stainless steel and non-magnetic.
Old 03-30-2017, 02:15 AM   #10
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
I RE-DID a Lincoln Model K-V-12 where someone used Intake valves in the Exhaust, burned the CRAP out of them! Fortunately, we had a donor car & took valves out of it.
SAME car lost a piston pin retainer & cut a slot in a cylinder wall
With a machinests' help, we bored & sleeved the hole, WITH THE ENGINE IN THE CAR!!!
Bill Dangerous
"THE ASSISTANT GURU OF STUFF"
Old 03-30-2017, 12:04 PM   #11
katy
katy's Avatar
Ford model A parts list shows both valves w/the same part #, A-6505-A
Old 03-30-2017, 12:29 PM   #12
d.j. moordigian
d.j. moordigian's Avatar
Learned the answer, to this question, 50 years ago in Collage.
I called Rusty with the answer,...we decided not to post anything,...looking for the smart
people. One sharp fellow, an engineer did answer..
If in doubt,...always use the non-magnetic valve (exhaust valve),..it's made from better
material, in either intake or exhaust. It will last longer..
d.j. moordigian is offline   Reply With Quote
