Old 03-27-2017, 09:11 PM   #1
Habusailor
Habusailor's Avatar
Default Tranny fluid level
How full do you fill the transmission on a 35 sedan? If I fill it to the level of the fill plug I loose a lot on the garage floor. Is it ok to fill so I can just touch the purple stuff when I put my pinkie in the plug hole?
Sent from my iPad using Tapatalk
Habusailor is offline   Reply With Quote
Old 03-27-2017, 09:33 PM   #2
40cpe
40cpe's Avatar
Default Re: Tranny fluid level
I usually put a 90 degree bend in a piece of wire with about 1/2" turned down. I stick the 1/2" piece down at the bottom of the plug hole. If I touch grease I think I'm OK.
40cpe is offline   Reply With Quote
Old 03-27-2017, 09:33 PM   #3
WestCoast
that's the way its done
WestCoast is offline   Reply With Quote
Old 03-27-2017, 10:02 PM   #4
Tinker
Tinker's Avatar
I fill till its full. Then quickly put the plug in.
Old 03-27-2017, 10:39 PM   #5
Vintage Copper 47
Vintage Copper 47's Avatar
Yup.. fill til spilling.. then get her in!
Vintage Copper 47 is offline   Reply With Quote
