Old 03-14-2017, 02:49 PM   #1
BUBBAS IGNITION
BUBBAS IGNITION's Avatar
Default Crabbie day at bubbas ??
Special crab distributor for a customer with a blown big inch flathead..Needed distributor to run 5000 plus rpms and supply 22-23 degrees at 2500.
We built a cast iron unit ( my favorite) used CS47 HD Napa contacts and a vertex condensor. Had a couple NOS Mallory brown caps as well. As good as it gets crab style!!!!!!!
If it Makes Spark, we do it !!!!
www.bubbasignition.com
[email protected]
BUBBAS IGNITION is offline   Reply With Quote
Old 03-14-2017, 03:10 PM   #2
petehoovie
petehoovie's Avatar
Default Re: Crabbie day at bubbas ??
I almost like it!.... I'd like it 'too many', if it were mine.....
Old 03-14-2017, 04:13 PM   #3
Ian NZ
Ian NZ's Avatar
Great looking distributor, see you used a Vertex condensor what is the M.F.D on these condensors.
Did you receive my email about the order, I had a bit of trouble sending it too you.
Ian NZ is offline   Reply With Quote
Old 03-14-2017, 05:09 PM   #4
BUBBAS IGNITION
The vertex is a .36mfd high quality 600 volt condensor........
[email protected]
Old 03-14-2017, 08:03 PM   #5
35fordtn
35fordtn's Avatar
Jim, do all these cast versions have a bushing in them for the vacuum brake?
35fordtn is offline   Reply With Quote
Old 03-15-2017, 08:56 AM   #6
BUBBAS IGNITION
Yes i have three on the bench right now and they all have the bushing. I like the look painted gloss black and they just seem to always work really well on the machine..
[email protected]
Old 03-15-2017, 09:21 AM   #7
BUBBAS IGNITION
[email protected]
