Old 03-11-2017, 05:56 PM   #1
Tom in SW VA
Tom in SW VA's Avatar
Default Timing a Model T
Could someone give me step by step instructions on timing a Model T?
From locating Top Dead Center on cylinder one (1) to step2 to step 3 to etc. .................
Thanks a million!
Tom in SW VA is offline   Reply With Quote
Old 03-11-2017, 06:54 PM   #2
redmodelt
redmodelt's Avatar
Default Re: Timing a Model T
See your other posting.
Old 03-12-2017, 11:33 AM   #3
Royce P
Royce P's Avatar
1. Pull out the #1 spark plug
2. Shine a light in the spark plug hole (flashlight)
3. Using the hand crank watch in the hole as you crank the engine. You are looking for the compression stroke where both valves are closed and the piston is coming upwards.
4. To determine the exact place the spark should happen use a plastic stir stick from McDonalds or a plastic straw. Place the straw on the piston as it approaches TDC on the compression stroke. You will feel the piston come to the top. The crank handle will move an inch or so with no movement of the piston, because the piston is "at" TDC.
5. Continue to gently turn the engine using the crank. When the piston just begins to move downward stop! This is where the spark needs to happen.
6. Lay the #1 spark plug on the head bolt with its wire connected.
7. Disconnect the timer rod from the steering column.
8. Turn the ignition on "BAT".
9. Adjust the timer until it the spark happens just after the piston passes TDC as in steps 1 - 5. You can repeat steps 1 - 5 with the key on to verify that you have indeed found the right spot.
10. Bend the timer rod so that the timer is in this position with the rod connected and the spark lever on the steering column is all the way up.
1910 Touring
1914 Touring
1915 Touring
1917 Torpedo Runabout
Royce P is offline   Reply With Quote
Old 03-29-2017, 11:39 AM   #4
Ed in Maine
I know bending a timer rod has done the job for 100 years but has anyone ever seen an adjustable timing rod? Ed
Ed in Maine is offline   Reply With Quote
Old 03-29-2017, 01:44 PM   #5
redmodelt
redmodelt's Avatar
Up to at least 1921 one end of the rod had a screw on ball joint that was somewhat adjustable.
Old 05-01-2017, 08:04 PM   #6
signsup
Here's mine. Came with some loose parts from an estate sale. Don't know if it is aftermarket or a Bubba part, but it's a neat idea. One end is threaded and the arm is tapped, so line up the end on the timing cover and then thread the other end in or out till it lines up. Sounds like batter than bending the rod to me.
signsup is offline   Reply With Quote
Old 05-02-2017, 05:11 AM   #7
29spcoupe
29spcoupe's Avatar
A friend of mine from the Boston area was making throttle rods like that. I have one on one of my T's. He's gone now, a great idea. john
29spcoupe is offline   Reply With Quote
Old 05-09-2017, 09:18 PM   #8
g502
Bob's sells them.
g502 is offline   Reply With Quote
Old 06-08-2017, 05:55 PM   #9
piewagon
Actually not so great of an idea. Most of the problems with getting proper clearance around timer rod is that people don't know that to properly set the timing and Not have it rub against anything is to start with a brand new rod properly made to factory drawing. Yes they do exist. To adjust the timing you should bend the rod ONLY in the ARC that the rod makes as it exits the timer and goes above the timer. To advance the timing you simply squeeze the arc together to reduce the end to end length but do it only in that upper arc. Likewise if you need to retard the timing you simply stretch the arc wider at the same location. What usually has happened is that someone installed an outside oiler on the engine and decided to bend the timer rod out of the way rather than forming the oil line being added to a shape that does not interfere with the timer rod. Top dead center is easy to find if you remember to setup the timing when the radiator is off the car. Just look into the front of the motor and note the position of the pin that holds the front fan pulley onto the crankshaft. EVERY TIME that pin is exactly horizontal, one of the pistons is exactly at TDC. That pin hole is reference angle 0.000 degrees when the cranks shaft is ground initially so that all of the throws are in proper location. You don't need anything but an operating set of coils and a battery to power the coil box. Just set the lever to full retard and turn on the ignition. Pull the hand crank slowly till you hear a coil buzz. STOP when you hear it and pull the hand crank back and look at the pin. IF the pin is sitting at the 10 o'clock - 4 o'clock position you are too retarded. Pull ahead slowly an stop when you hear buzzing again and you will see that every time you stop the hand crank when you hear buzzing, the pin is in exactly the same position. If the pin is in the 8 o'clock - 2 o'clock position you are too advanced. What you want is the pin to be just past the 9 o'clock - 3 o'clock position. What this means is that just look at the right hand end of the pin and make sure it has PASSED the 3 o'clock position but only but a small amount. That is then what I call the 3:15 O'clock position. Verify that you get that exact position on each of the 4 cylinder and your T will be very easy starting. All of this timing adjustment is done with the lever in full retard position. Just pull the hand crank up ever so slowly and STOP when you hear the buzz and look at the pin. If it is in the 3:15 position - you are spot on perfect. I have set all of my cars this way for years and even verified it with a degree wheel and it is always exactly correct because all Ford T cranks made by Ford have the pin hole in exactly the same angular position.
piewagon is offline   Reply With Quote
