Old 03-11-2017, 06:59 AM   #1
farmerdick
farmerdick's Avatar
Question 1939 Clutch and Brake Pedal Bushings
Hey Guys, What have any of you done to replace the 39` clutch and brake pedal bushings? None of the reproduction dealers have them. I was thinking of getting a piece of copper pipe and have it machined to the correct ID & OD dimensions. Thanks
Richard
farmerdick is offline   Reply With Quote
Old 03-11-2017, 07:50 AM   #2
Charlie ny
Default Re: 1939 Clutch and Brake Pedal Bushings
I don't think copper is such good idea. If you know anyone with a lathe and a bit of
savvy perhaps they could do the job using the correct bronze bushing material.
Don't be surprised if you discover excessive shaft wear and pedal bushings worn thru
to the steel and beyond. Been there.
Failing the above I'll take the job, PM me if you wish.
Charlie ny
Charlie ny is offline   Reply With Quote
Old 03-11-2017, 08:18 AM   #3
richard crow
drake reproduces the whole assembly may be he would sell the bushings would not heart to call him
richard crow is offline   Reply With Quote
Old 03-11-2017, 08:34 AM   #4
texas webb
Mac Van Pelt has them,just talked to him about parts for mine.
texas webb is offline   Reply With Quote
Old 03-11-2017, 10:52 AM   #5
outlaw
You should be able to go to your local bearing supply house (if you have one) near by, & they should have bronze bushing material in stock. They might have the correct size if the dimensions you need are a nominal size. Also check Grainger & McMaster & Carr.
outlaw is offline   Reply With Quote
Old 03-11-2017, 01:43 PM   #6
farmerdick
farmerdick's Avatar
A lot of great ideas here, that you`ve given me. I will start with VanPelt then Drake and if need be I`ll go with the bronze bushing material. Thank you all again for the help.
Richard
