Old 03-10-2017, 09:35 PM   #1
Bruce in southern OH
Bruce in southern OH's Avatar
Default Where is the horn relay located on a 1966 Lincoln
Horns do not work, checked horns, will sound if 12 volt is connected. Removed the center cover of steering wheel, have continuity. Cannot find the horn relay, I have a service manual, but it does not show were the relay is located. This is a Convertible car, thanks Bruce
Bruce in southern OH is offline   Reply With Quote
Old 03-14-2017, 04:00 PM   #2
scrapiron
Default Re: Where is the horn relay located on a 1966 Lincoln
Horn & signal wires should come out of the column under the dash, likely nearby,,,maybe,,,
scrapiron is offline   Reply With Quote
Old 03-14-2017, 06:52 PM   #3
miker98038
miker98038's Avatar
I found this on a Lincoln site, maybe it will help.....
I have a '61 and the fuses are located in the "Power Box." You will find
it mounted on the firewall on the passenger side. The battery cable
connects to this box which contains all relays and fuses.
If you cannot find fuses on your '66 check for a power box.
-Ken-
Sign in to reply
12/13/96Leon Rowell
On my '69 Mark III it is in the glove box behind a plastic cover on the
right side.
Leon Rowell
Sign in to reply
12/15/[email protected]
[email protected] (k-rad) wrote:
- show quoted text -
>Thanks
>Durin Gleaves
>[email protected]
I have a '64 Lincoln, and the actual fuses are located behind a small
removable pannel in the front of the glove box. Luckily mine was off
when I bought it. There is also a set of circuit breakers, and
other electrical components behind the passenger side kick panel. Just
remove the carpet, and it'll be there. That's where I found the fuse
for the horn (go figure). It's an interesting vehicle. Tons of
spaghetti to get lost in. The fun starts when you have to go
through the vacume hoses.
Dennis N.
[email protected]
miker98038 is offline   Reply With Quote
Old 03-15-2017, 03:05 PM   #4
Thank you, I will look at the locations when the temp get in double digit, Cold here in southern OHIO, Saturday looks good, Bruce
