Old 03-10-2017, 02:35 PM   #1
bmwillia
bmwillia's Avatar
Default Help with 1933 Grill attachment
I am mocking up my car and have the fenders attached.
I cannot figure out an easy way to bolt the grill to the pie shaped deflector and the fenders. It seems to me that there should be cage nuts around the inner chin of the grill, but my grill(which I believe is original) does not have any.
Any help would be appreciated.
Brad Williamson
bmwillia is offline   Reply With Quote
Old 03-10-2017, 02:47 PM   #2
FlatheadTed
FlatheadTed's Avatar
Default Re: Help with 1933 Grill attachment
Should have a D nut between the 2nd and 3rd indentation on the grill about 6" up ,one bolt down on the centre cast divider ,another one into the inner guard about 15" up Ted
http://www.flatheadted.com
Flathead Ted brake Floaters ,
Old 03-10-2017, 02:52 PM   #3
bmwillia
bmwillia's Avatar
Thank you Ted.
Do you have any pictures you could share?
Brad Williamson
Old 03-10-2017, 03:27 PM   #4
FlatheadTed
See how I go tonight Ted
Old 03-10-2017, 10:19 PM   #5
johnboy34
You might find it easier without the fenders first. Install radiator, inner fenders, grill then hood. Once you have that looking good install fenders and adjust fender brackets to fit.
johnboy34 is offline   Reply With Quote
Old 03-10-2017, 10:31 PM   #6
bmwillia
bmwillia's Avatar
Thanks John.
My question is more to do with how the Grill bolts up to everything. There is no way to get my hand in there to hold a nut or bolt. Because of that, I am assuming that there was some sort of cage nut attached to the grill but from Ted's post that is not the case.
Brad Williamson
Old 03-11-2017, 12:19 AM   #7
deuce_roadster
deuce_roadster's Avatar
With everything loose, you can slip one of those nuts attached to a "U" shaped piece of spring steel onto the edge of the grille leaving the nut over the hole. With the welting in place you won't see the small gap caused by the "U" shaped part. Then you can install the bolt from below.
I had to do this on my 33 as the grille was missing 1 of the D nuts.
Old 03-11-2017, 03:59 PM   #8
FlatheadTed
On my post I said there's a D /caged nut on the side .the heart shaped pan goes on the fenders first ,then the grill ,bolted through from under . Ted
Originally Posted by bmwillia View Post
Thanks John.
