Old 03-01-2017, 01:05 PM   #1
JOHN CT
JOHN CT's Avatar
Default Leakless water pump
I have a leakless water pump it's the type that the rear bearing needs to be greased. The instructions said to loosen the packing nut so the grease doesn't go into the coolant. So that's what I did. The question I have is how tight do I tighten the packing nut ? Do I make it finger tight or just tight enough to hold things together? I don't want to over do it it's a 1 year old pump
31 Tudor
66 Bonneville
57 Chevy pickup 27 T roadster pick up
JOHN CT is offline   Reply With Quote
