Old 02-27-2017, 06:15 PM   #1
[email protected]
Default 1932 Detroit Lubricator carb, dash light, engine dust pans
Hello all,
Need some help in finding someone to take a look and possibly help rebuild a 1932 Detroit Lubricator carb-it runs fast now on the car, leaks below on the intake. One guy I read about elsewhere said it might cost $2500 including machining of parts-no thanks. I have called around but haven't been able to find any kits for them-need a gasket for sure. Maybe just a good cleaning and adjustment? Need someone reliable and would prefer local in southwest Ohio or as close as possible?
Also need a set of engine dust pans for the v-8 model. If rough shape, I can work them.
Also need a dash light-the light I have is a repo as well as the cluster housing is a repo and it doesn't fit-the housing is much larger than the light, needs some fixturing or an original one to fit? Or ? Any experience you have on this is appreciated!
Thanks Fordbarn!
Tim
tjh6x6@aol.com is offline   Reply With Quote
