Old 02-25-2017, 12:23 PM   #1
V8Germany
V8Germany's Avatar
Default Steering rumbles while driving! Help !!!
Hi Forum,
I'm in Germany and own a Modell 68 Fordor Sedan from 1936.
Car just got full approval from german Technical Control Board.
This morning we did the Maiden trip...1 mile...
Then suddenly the steering started rumbling, the front of the car
was shaking/ vibrating and the steering felt soft and with no connection
to the wheels.
The vibrations stopped when I slowed down, but came back, independent
from the speed.
Air pressure in the tyres ok, tyres seem to be fix.
The rumbling was as strong that I nearly did not dare to drive home.
And idea, help ?
See pics
V8Germany is offline   Reply With Quote
Old 02-25-2017, 12:39 PM   #2
petehoovie
petehoovie's Avatar
Default Re: Steering rumbles while driving! Help !!!
Loose/worn tie rod or pitman arm. Steering box problem. Loose wheels?
Old 02-25-2017, 12:44 PM   #3
V8Germany
V8Germany's Avatar
Wheels seem to be ok.
Thx, for the support.
Old 02-25-2017, 01:12 PM   #4
Andy
I had a similar problem that was fixed with new kingpins/bushings.
Andy is offline   Reply With Quote
Old 02-25-2017, 01:47 PM   #5
flatford8
flatford8's Avatar
Loose wheel bearings?..... Dry steering box?..... Mark
I'm thinkin' about crankin'
My ragged ol' truck up
and haulin' myself into town.
Billy Joe Shaver…RIP
Old 02-25-2017, 01:52 PM   #6
SofaKing
SofaKing's Avatar
Its hard to believe German inspection would have missed worn kingpins or loose steering components but it is a good place to start. Check also the front spring bolts and the radius rod ball rubber pad and attachment for wear or looseness. Verify that your shocks are working properly and evenly on both sides. I'd also investigate the steering feeling "disconnected" and verify that was just a feeling and not a mechanical failure in the steering mechanism or sheared key in the steering wheel.
SofaKing is offline   Reply With Quote
Old 02-25-2017, 02:01 PM   #7
V8Germany
V8Germany's Avatar
I share your thoughts about our German Inspection �� Thanks
for the input. By the way, car is from the Salt Lake City area :-)
Old 02-25-2017, 02:02 PM   #8
Ed Pitts
Ed Pitts's Avatar
Also check the toe in.
Ed Pitts is offline   Reply With Quote
Old 02-25-2017, 03:40 PM   #9
V8COOPMAN
V8COOPMAN's Avatar
Your "rumbling" in your steering sounds like what many folks refer to as the "death-wobble", where the front wheels begin violently shaking from side to side, uncontrollably. Click the link below for hours of reading about, and theoretical remedies for the death-wobble here on the FordBarn. DD
http://www.fordbarn.com/forum/showth...t=death+wobble
Click Links Below __
T5 W/TORQUE TUBE
Old 02-25-2017, 04:11 PM   #10
V8Germany
V8Germany's Avatar
Wow :-( Thanks
Old 02-25-2017, 05:15 PM   #11
tubman
tubman's Avatar
Mr. Coopman, are you sure that link is OK? When I click on it it says it can't be found. (Tried it twice.)
Old 02-25-2017, 05:22 PM   #12
V8COOPMAN
V8COOPMAN's Avatar
Not sure what transpired there.......try this link! DD
T5 W/TORQUE TUBE
Old 02-25-2017, 05:22 PM   #13
JSeery
JSeery's Avatar
Worked for me, it is a search page.
The second link is an actual thread.
Old 02-25-2017, 05:23 PM   #14
supereal
supereal's Avatar
If the tire inflation is correct all around, and there isn't lots of play in the steering gear or other parts, it is likely the toe-in of the front wheels is incorrect. I have seen this in Model A's so bad that the car had to be stopped to get rid of the wobble. If the toe in shows about zero to 1/16", but the shimmy is still there, swap the front and back wheels and tires. If that cures or changes the problem, look for a bent wheel or out of round tire. Tire balance may contribute to the problem, but usually not to a severe degree.
supereal is offline   Reply With Quote
Old 02-25-2017, 08:14 PM   #15
36coupe
36coupe's Avatar
Some simple checks you can do. Have someone wiggle the steering wheel back and forth and check the steering components for excess play.
If your wheels are toed out too far you can get death wobble on uneven surfaces.
Good luck.
36coupe is offline   Reply With Quote
Old 03-18-2017, 05:15 PM   #16
J Franklin
J Franklin's Avatar
I had an out of round tire that caused shimmy Or rumble as you say.
Old 03-18-2017, 06:08 PM   #17
V8Germany
V8Germany's Avatar
Problem solved, thank you for the help. A couple of loose screws @ steering gear.
Old 03-18-2017, 08:01 PM   #18
Paul Bennett
My car has a loose nut behind the wheel.
Me Gramps told me that, can't belive I repeated it, musta came from 1903.
Paul Bennett is offline   Reply With Quote
