Old 02-20-2017, 08:44 PM   #1
jerrod1932
Default 1928 cab back window with Ford script above it?
A friend of mine found one of those rare 1928 cab back panels with the ford script above it. I need some help indentifying it though. rather than having the window up high, it has a rather large window about double the normal size. this looks factory as it has all the garnishes and correct beads and ribs, around it. Does anyone know anything about this rare bird haha? thanks david [email protected]
jerrod1932 is offline   Reply With Quote
Old 02-20-2017, 08:54 PM   #2
denis4x4
denis4x4's Avatar
Default Re: 1928 cab back window with Ford script above it?
Can you post some photos please?
No restorable Model A's were harmed in the building of this truck!
denis4x4 is offline   Reply With Quote
Old 02-20-2017, 08:59 PM   #3
SeaSlugs
SeaSlugs's Avatar
Yea we need some pics before any speculation... Wouldnt happen to be in canada would you?
1929 Model AA - Need long splash aprons!
SeaSlugs is offline   Reply With Quote
Old 02-20-2017, 09:04 PM   #4
Tim
Said friend posted picture :-). Yep - what is it? and as Dave said this is stamped and uses very nice reveals and a factory appearing garnish.
Thanks Dave!
- Tim
Tim is offline   Reply With Quote
Old 02-20-2017, 09:24 PM   #5
SeaSlugs
SeaSlugs's Avatar
my first guess is someone cut the hole bigger.... the bolt holes arent even all the way around when im sure a factory job they would be...nor would the square nut interfere with the ford logo. Tts a really small window normally and theres a reason they moved it down after the early 28's so my guess someone made it bigger...
Got any inside pics?
Old 02-20-2017, 09:30 PM   #6
Gary WA
Gary WA's Avatar
Commercial Ford Car Hauler?
www.whidbeymodelaclub.com
Old 02-20-2017, 10:31 PM   #7
Tim
1928 Ford Model AA telephone truck looks like it has a large rear window. Does anybody have one of these or pictures of the cab?
My first thought was a Car Hauler as well, but I can only find pictures of them with small windows. Maybe a Jail or Prisoner Hauler as well?
Thanks - Tim
Old 02-20-2017, 10:48 PM   #8
Gary WA
Gary WA's Avatar
maybe?
Old 02-20-2017, 11:00 PM   #9
Tom Wesenberg
Tom Wesenberg's Avatar
Yep, I agree that it looks home cut for a larger glass.
Old 02-21-2017, 10:35 AM   #10
Tim
No it's pressed and rolled and one solid rolled or stamped piece. IT's too nice to be a home cut job. The flanging is really nice with square corners you only get when a piece is stamped. Also there's a lack of hammer marks if it was done as a one off for the glass channel. I'll get a few more pictures. We may never know the real story. But it'd be nice to figure it out. Certainly not a mass production thing. Maybe a specialty order for a one off client.
- Tim
Old 02-21-2017, 10:37 AM   #11
Tim
Just caught this, unfortunately I'm in Aptos CA.
Old 02-21-2017, 10:43 AM   #12
denis4x4
denis4x4's Avatar
When I was rebuilding the '29 cab in my avatar with 6-1/2" stretched corners, I used new sheet metal for the upper rear panel. I debated as to whether to cut out a larger rear window as the way the panel was formed, it would have looked "factory". Looked at Jeep CJ windshield rubber to fit the larger glass. Full disclosure: the top was fitted with white oak custom bows...metal rods were used to align the body.
Old 02-21-2017, 11:50 AM   #13
Bulligen
Bulligen's Avatar
It looks like a Model T 2dr sedan window molding
Bulligen is offline   Reply With Quote
Old 02-21-2017, 11:26 PM   #14
SteveB31
SteveB31's Avatar
It is an early 1928 Aa cab that has had a larger window hole cut in right at the original bead molding.
SteveB31 is offline   Reply With Quote
