Old 02-10-2017, 04:26 PM   #1
tubman
tubman's Avatar
Default Removing 8BA oil fill tube
I just came into possession of an aluminum Sharp 4 BBL manifold for an 8BA. Although it is a solid piece, with no chips, cracks, or bad bolt holes, it must have been stored in less than ideal conditions for a long time, because the finish is quite corroded. A stock 8BA oil fill tube is installed, and it must have been there a long time as well, as it has substantial surface rust There is a lot of corrosion where the oil fill tube fits in the manifold. I have soaked it in PB Blaster for two days, and try as I might, I can't get it out. I have removed these tubes from several manifolds before and have never has one as stuck as this one. Because of the way the casting was made, you can't get in from the bottom and use a punch like I have done in the past. I think it is time for a little heat. It would seem that some heat applied to the manifold might be the best way to go, because I think aluminum expands more than steel. Or maybe I should heat the steel tube?
Does anyone have any insight on how to proceed with this?
Old 02-10-2017, 04:30 PM   #2
V8COOPMAN
V8COOPMAN's Avatar
Default Re: Removing 8BA oil fill tube
Have you tried tapping it out from the bottom side with an appropriate tapping-out tool? DD
Click Links Below __
T5 W/TORQUE TUBE
Old 02-10-2017, 04:33 PM   #3
tubman
tubman's Avatar
The computer somehow posted the thread when I had it only half done for some reason. When I finally finished entering it, I stated that the design of the manifold precludes this, which has always worked for me in the past.
Old 02-10-2017, 04:42 PM   #4
V8COOPMAN
V8COOPMAN's Avatar
It might be time to just go ahead straight to a pipe wrench. DD
T5 W/TORQUE TUBE
Old 02-10-2017, 04:43 PM   #5
V12Bill
V12Bill's Avatar
Aluminum melts at a low temp. Tap the fill tube on the the sides near the top and give it a rocking, pulling motion by hand. Try a penetrating oil.
V12Bill is offline   Reply With Quote
Old 02-10-2017, 04:59 PM   #6
tubman
tubman's Avatar
I don't think you could melt the manifold with a propane torch, could you? Like I said, I've done this several times before, and this one is stuck! I really don't want to use major force for fear of breaking the manifold. I thought I'd try a finesse' approach with heat first.
Old 02-10-2017, 05:08 PM   #7
Russ/40
Russ/40's Avatar
Cut it off where it meets the manifold, and use a hacksaw blade to carefully split what remains. Then you can reinsert what's left of the tube if it's OK, or find a better tube. I always like to shorten the 8BA tubes anyway as they are so long. They look much better when shortened.
Russ/40 is offline   Reply With Quote
Old 02-10-2017, 05:18 PM   #8
51 MERC-CT
51 MERC-CT's Avatar
Like V12bill says, tap the upper end of the tube in all directions (including as if installing ) Do not cut it off or you will be on the way to opening up a can of worms.
Old 02-10-2017, 05:27 PM   #9
V8COOPMAN
V8COOPMAN's Avatar
Aluminum, depending on the mix, can begin to melt a little before 1,300 F. DD
T5 W/TORQUE TUBE
Old 02-10-2017, 05:37 PM   #10
tubman
tubman's Avatar
"Google" says that an air-only propane torch (like a garden variety Bernzomatic) burns at more than 3500 degrees F! I did not know that. I guess melting the manifold could be a concern!
Old 02-10-2017, 05:39 PM   #11
Craig CT
Craig CT's Avatar
Hi tubman; I'd drill a 3/8" to 1/2" hole through the tube about half way up and slide a one foot or longer rod through the hole and twist it out. Good luck, Craig.
" When I was a boy of fourteen, my father was so ignorant I could hardly stand to have the old man around. But when I got to be twenty-one, I was astonished at how much he had learned " Mark Twain.
Craig CT is offline   Reply With Quote
Old 02-10-2017, 05:45 PM   #12
Paul Selfe
Paul Selfe's Avatar
Heat up the tube with a propane torch (it won't need a lot of heat) then melt some candle wax around the base of the pipe. Then tap the top of the pipe all around (as someone else said), it should loosen so you can twist it out. Paul Selfe.
Paul Selfe is offline   Reply With Quote
Old 02-10-2017, 06:18 PM   #13
Ronnie
Ronnie's Avatar
Yup x 2 ^^^^
You won't harm the manifold with a propane torch.Don't try and remove until it cools somewhat it may take a couple of try's but it will come out.
R
Ronnie is offline   Reply With Quote
Old 02-10-2017, 06:19 PM   #14
flatjack9
flatjack9's Avatar
I'd start out using a heat gun, rather than a torch.
Old 02-10-2017, 06:51 PM   #15
tubman
tubman's Avatar
Thanks for the tips guys. I'm going to try a little heat, tapping, and penetrants first. This is a casting that is at least 60 years old and of questionable initial quality. I've seen too many aftermarket intakes over the years with broken flanges, broken bolt bosses, cracks, and especially damage to the generator mounting flanges to be wary of trying anything with a lot of brute force. If all of this fails, I'll probably try "Russ/40"'s method and cut it off flush; I'm sure I can get the remnants of the tube out with careful use of a die grinder. I agree with him that they're too tall stock. Wish me luck; I'm sure I'll get it. Patience is a virtue in a case like this.
Old 02-10-2017, 08:03 PM   #16
Lanny
Lanny's Avatar
Hey Denny, are you having fun yet
As Paul Selfe said a few post above, use a little heat
and melt in a little candle wax (paraffin wax).
I've had success getting stuff apart with paraffin,,,good luck
If mama ain't happy, ain't nobody happy.
But if daddy ain't happy...RUN
What I GOT DONE TODAY...
I got the rear-end put in the recliner, and
now I'm going to rest up & watch TV
Lanny is offline   Reply With Quote
Old 02-10-2017, 09:15 PM   #17
Ol' Ron
Ol' Ron's Avatar
50/50 mix will work the best as a releasing agent. Also put the intake in an oven and bring it up to 350 for an hour or so. might loosen it up.
Old 02-10-2017, 09:27 PM   #18
19Fordy
19Fordy's Avatar
Cut it off and use the die grinder to carefully grind thru the wall of the tube so you can split it and pull it out.
Old 02-10-2017, 09:35 PM   #19
AnthonyG
AnthonyG's Avatar
Aluminum moves more with heat than steel. You should be able to heat the manifold to a 200 to 300 F degrees in an oven then remove and at the same temp the aluminum should expand more than the steel at the same temp, see the table. prior to the heating have a 1/2" or 5/8" hole drilled thru the oil fill to put a rod thru to give some torque to work it out. the steel should break free. Another trick as the aluminum has more mass and will hold radiat the heat longer is to apply a chunk of ice or cubes in a wet towel around the steel tube to ampifie the difference in the Thermal Expansion difference.
http://hyperphysics.phy-astr.gsu.edu...les/thexp.html
Nomad
AnthonyG is offline   Reply With Quote
Old 02-10-2017, 10:08 PM   #20
tubman
tubman's Avatar
I like the oven approach. I think that's gonna be my first try at this. Anthony, thanks for the information; that's exactly the what I was looking for when I started this thread. When I get it out of the oven, I think I'll just fill the tube with ice cubes and crank away.
Now, if I can just get the ole lady out of the house for a couple hours.......
