Old 01-30-2017, 05:15 PM   #1
newshirt
newshirt's Avatar
Default Hub seal orientation
I want to verify the rear hub seal (and rear inner axle seal) orientation before pressing them in.
I believe the seals are oriented with the metal spring toward the grease. My attached photo shows the outsides of the seals, oriented away from the grease, true?
Can anyone confirm?
Ray White
newshirt is offline   Reply With Quote
Old 01-30-2017, 05:27 PM   #2
JDupuis
JDupuis's Avatar
Default Re: Hub seal orientation
That's how I mount them.
JDupuis is offline   Reply With Quote
Old 01-30-2017, 05:33 PM   #3
Bob C
I'll save myself a thousand words.
Bob
Old 01-30-2017, 06:30 PM   #4
Tom Endy
Tom Endy's Avatar
The original inner hub seals were made of leather. One of Fords suppliers was Chicago Rawhide. Quite often the original seals are found still in place during an overhaul. The letters CR are found stamped on the side. Most of the leather is usually deteriorated.
It made sense to install them such that when the axle slid into place it did not fold the leather back on itself.
Modern replacement seals are made of neoprene. Supplier's literature say to face the taper on the seal toward the lubricant. There is a taper on both sides of the seal and it is not specified what lubricant they are talking about, the oil in the banjo or the grease that is pumped into the rear wheel bearing.
The seal is a grease seal, not an oil seal. Its purpose is to prevent the grease that is pumped in through the grease fitting on the rear backing plate from migrating down the axle shaft toward the differential instead of going outboard to the rear wheel bearing.
People continue to argue about the purpose of the seal and which direction to face it. If you have ever pulled a rear end apart that had the original shot seals installed and an owner who religiously pumped grease into the grease fitting on the backing plate you would find that grease has centrifuged around the axle an inch thick and is as long toward the differential as the owner's frequency of pumping grease into it.
I don't think it matters which direction you face the seal, either way it will snap into the slight groove in the axle and it will do the job.
It is best to pack the rear wheel bearings when you have the drum off and forget about that grease fitting. Ford eliminated it during the early V8 years.
Tom Endy
Tom Endy is offline   Reply With Quote
Old 02-09-2020, 11:37 AM   #5
stengel
Newbie here so I put what I call the open end toward the bearing that I greased ,CORRECT? It seams that the grease would eventually fill the opening that is in the seal side with the spring in it ???? WOW.
stengel is offline   Reply With Quote
Old 02-09-2020, 11:51 AM   #6
DBrer
Thats how I would install a seal.
DBrer is offline   Reply With Quote
Old 02-09-2020, 11:53 AM   #7
Jim Brierley
stengel, correct, the seals are to keep the grease in the wheel bearing.
Jim Brierley is offline   Reply With Quote
Old 02-09-2020, 01:06 PM   #8
redmodelt
redmodelt's Avatar
I put mine on so any part that slides into or onto you don't have to fight the taper in the seal so the open side is to the grease not away. When grease is added, you want the lip to be pushed to seal, not pushed to open and allow the grease past.
