Old 01-28-2017, 09:18 PM   #1
Green&White
Default Door switch delete on '59 Custom Fordor
For cars that were not equipped with the optional (?) door switch to automatically turn on/off the courtesy light, was there a rubber delete plug the cover the hole ? (see yellow arrow in the attached photo). The car on the left (my Dad's) seems to have had such a cover; the one on the right (mine) does not.
If they exist, where can I obtain a pair?
'59 Custom 300 - Fordor.
Green&White is offline   Reply With Quote
Old 01-30-2017, 11:21 AM   #2
Troublemaker427
Default Re: Door switch delete on '59 Custom Fordor
My '61 Fairlane is a switch delete and it did not have a plug there, just the same type of hole as your '59.
I've heard of them possibly having plugs but I'm 99.9% sure my car never had one. My car was untouched when I bought it and they are missing on both sides.
Troublemaker427 is offline   Reply With Quote
Old 01-31-2017, 07:13 AM   #3
LOWRIDER
LOWRIDER's Avatar
You might try measuring the size of the hole then trying one of those rubber body plugs. Different sized plugs are available from all the normal suppliers. Dennis Carpenter, Macs and others.
Dan Kingman Az. 86409
LOWRIDER is offline   Reply With Quote
Old 01-31-2017, 11:37 AM   #4
dmsfrr
dmsfrr's Avatar
deleted
dmsfrr is offline   Reply With Quote
Old 01-31-2017, 11:48 AM   #5
dmsfrr
dmsfrr's Avatar
Many home hardware stores have: rubber plugs, caps, specialty nuts, threaded inserts and misc handy do-dads on the aisle with drawer pulls and cabinet handles.
Old 01-31-2017, 01:08 PM   #6
50fordcoupeman
50fordcoupeman's Avatar
I got some plugs from NAPA. They had a large selection of plugs. They had plastic, rubber and even some chrome plugs.
50fordcoupeman is offline   Reply With Quote
Old 02-01-2017, 09:06 AM   #7
bobss396
bobss396's Avatar
I have never seen one plugged before. Even the lowly Custom 300 had the switches on both sides. You could try to see if Steele Rubber makes one, plug in what car you have and it generates a list. Any standard body plug will work once you know the size.
bobss396 is offline   Reply With Quote
Old 02-02-2017, 11:52 AM   #8
Green&White
Interesting. If door switches were standard on the Custom, then maybe what I'm (barely) seeing in the B & W photo is the switch.
- Would it have looked like in the attached photo ?
- Would the Fordor have had it on the back doors as well ?
If mine were removed for repaint, then I would think the wires are still in there somewhere. If not, what additional wiring / hardware / dis & re-assembly would I need to get it working ?
Thanks
Old 03-20-2017, 10:33 PM   #9
Green&White
I've seen photos of the rubber plugs. Here are a couple examples:
Old 03-21-2017, 09:55 AM   #10
54vicky
54vicky's Avatar
if you go to Jeffs 52-59 ford social forum on the HAMB. look at dagels build there are shots of the door jambs showing plugs.look pretty original.if you do not belong it would benefit you to join.
54vicky is offline   Reply With Quote
Old 03-21-2017, 04:47 PM   #11
40cpe
40cpe's Avatar
How do I get to and join the social forums? I'm not very HAMB-savy.
40cpe is offline   Reply With Quote
Old 03-21-2017, 06:45 PM   #12
bobss396
bobss396's Avatar
Well... we would have to like you first.... are you already a main board HAMBer?
Old 03-21-2017, 07:31 PM   #13
40cpe
40cpe's Avatar
See, I'm not HAMB savy. I am a member, log-in, etc, but don't know about main board. I don't post but lurk occasionally. I'm looking at a '55 Victoria.
Old 03-22-2017, 09:01 AM   #14
54vicky
54vicky's Avatar
I sent you a PM if any questions ask
Old 03-23-2017, 08:40 PM   #15
WestCoast
find the size of the hole, then go to the wrecking yard and get what you need ofrom cars or truck door bumpers
WestCoast is offline   Reply With Quote
