01-23-2017, 01:38 PM | #1 |
Firewall ID
Can any one identify the attached firewall...
Is it for a car or truck and what year ???.... Silly me bought it for my 35 Phaeton project.......Any thoughts will be appreciated. Jim
______________________________________________ jfc I couldn't repair the brakes, so I adjusted the horn louder.... |
01-23-2017, 02:39 PM | #2 |
Re: Firewall ID
Looks like a 1940 car to me.
01-23-2017, 07:36 PM | #3 |
Re: Firewall ID
I believe that is for a 39 deluxe Ford car. 40 had a more pronounced area where the choke/throttle rods exit and a little different at the bottom for the "feet" as well.
01-23-2017, 08:31 PM | #4 |
Re: Firewall ID
It's '39 deluxe or early '40. There's no holes for the windshield wiper motor to bolt on. The wiper motor bracket should be spot welded to the inside of the firewall. I've seen early '40s with the spot welded bracket
01-24-2017, 01:01 PM | #5 |
Re: Firewall ID
Thanks to each of you for your inputs.. his helps me a lot...
Jim
01-24-2017, 02:26 PM | #6 |
Re: Firewall ID
01-24-2017, 02:55 PM | #7 |
Re: Firewall ID
No cutout/box for battery on passenger side = 1940; was not aware of change for choke/throttle rod "bumps" for mid-late production, something else to look for when checking cars out.
Alan H. Tast AIA, LEED AP BD+C Technical Director/Past President-Editor-Publications Director, Vintage Thunderbird Club Int'l. (VTCI) http://www.vintagethunderbirdclub.net Author, "Thunderbird 1955-1966" & "Thunderbird 50 Years" 35+ year member, Crown Victoria Ass'n. |
01-24-2017, 03:03 PM | #8 |
Re: Firewall ID
I thought the '40 had a notch in the driver side for the shift rod on top of the column.
01-24-2017, 03:58 PM | #9 |
Re: Firewall ID
I'd say this '39 Deluxe is a dead ringer. DD
01-24-2017, 07:07 PM | #10 |
Re: Firewall ID
Looks identical to me.
Sal |
01-25-2017, 11:02 AM | #11 |
Re: Firewall ID
DD... looks like you nailed it, thank you an everyone pitching in...
I have had the firewall 15 plus years never knowing what year it was for, now to find a good home for it.. Thanks again Jim
