Old 01-17-2017, 05:56 PM   #1
whizzernick
whizzernick's Avatar
Default oil pan diaper
photos show a diaper I am now making.
also I think a picture of my 33 phaeton
see oil spot on floor (short drive with only 1 stop)
Fords leak one teaspoon of oil after every shutoff of engine
this diaper is made from light colored vinyl so you can see in pictures
the ones I make and sell are made from black top material
pictures show how to attach and use old polish cloth to hold oil.
remove and toss when full ( depending on use could be 2 to12 months.
I also make a small one for steering and one for rear end.
I know cardboard is another way to catch oil drips but my diaper goes wherever you go and keeps other peoples driveways clear of your drips.
( they all drip)
P.S. I wanted to post larger pictures but was not able to find out how to do it. several people tried to help but I guess I am just to old or not to good with a computer.
whizzernick is offline   Reply With Quote
Old 01-17-2017, 06:03 PM   #2
petehoovie
petehoovie's Avatar
Default Re: oil pan diaper
Old 01-17-2017, 07:17 PM   #3
JimG
JimG's Avatar
Cool Re: oil pan diaper
What holds it on - magnets?
JimG is offline   Reply With Quote
Old 01-17-2017, 08:01 PM   #4
whizzernick
yes
Old 01-17-2017, 08:08 PM   #5
Lawson Cox
Lawson Cox's Avatar
What speeds do you drive at? Won't it blow off at higher speeds?
Old 01-17-2017, 08:27 PM   #6
whizzernick
will not blow off. tested at freeway speeds the type of magnets are so strong that they are hard to lift off a metal surface.
Old 01-17-2017, 08:31 PM   #7
Talkwrench
Talkwrench's Avatar
Don't mind the idea.. Cleaver thinkin'.
"Came too close to dying to stop living now!"
Talkwrench is offline   Reply With Quote
Old 01-17-2017, 10:27 PM   #8
Lawson Cox
Lawson Cox's Avatar
What do you get for one to fit 39 Ford engine?
Old 01-17-2017, 11:59 PM   #9
whizzernick
you are looking at $40 + shipping (cost)
Old 01-18-2017, 01:26 AM   #10
quickchange34
quickchange34's Avatar
Why not just fix the leaks?
quickchange34 is offline   Reply With Quote
Old 01-18-2017, 03:25 AM   #11
Lawson Cox
Lawson Cox's Avatar
Flathead leaks are so common they have a part number.
Old 01-18-2017, 08:23 AM   #12
trainguy
trainguy's Avatar
Great idea. One potential problem ,Fire Hazard!
trainguy is offline   Reply With Quote
Old 01-18-2017, 08:26 AM   #13
whizzernick
explain ?
Old 01-18-2017, 03:54 PM   #14
Ronnieroadster
Ronnieroadster's Avatar
Hey its cheaper than changing the oil!
Ronnieroadster is offline   Reply With Quote
Old 01-19-2017, 10:37 PM   #15
Kahuna
Kahuna's Avatar
My flathead does not leak
Kahuna is offline   Reply With Quote
Old 01-20-2017, 12:18 AM   #16
Paul Bennett
I've owned several Mercedes Benz sedans which had factory 'oil trays' under the engine which accumulated considerable drips before needing cleanout. You don't need to be embarrassed or make excuses. MB trays were molded plastic bolted to something. When I would have the oil changed they would always add 'drip tray full' to the inspection list. I was once told at highway speeds the tray was designed to 'clear'. Guess EPA had something to say about that.
Paul Bennett is offline   Reply With Quote
Old 01-20-2017, 02:24 AM   #17
Lawson Cox
Lawson Cox's Avatar
Too late to send it back under factory warranty. LOL
Old 01-20-2017, 07:12 AM   #18
dwick01
dwick01's Avatar
I am almost the same age as my car. Sometimes, I have leaks too........
dwick01 is offline   Reply With Quote
