#1 |
Mitchell over-drive or syncro transmission? Both of these upgrades are similarly priced. Which provides the better overall driving experience? Both of these could lend its self to safer operation while sharing the road with modern cars.
#2 | |
Location: Here I am in front of Todd's Grocery in 1931 selling Grit newspapers
I asked the same question to Larry Shepard.....overdrive was his answer if keeping up with the Jones on a highway/interstate. Lot's of city stop and go, syncro trans.
"Bullshit and Brilliance Comes with Age and Experience" "Hey Lady, ya wanna buy a Grit?" "If you don't learn to laugh at trouble, you won't have anything to laugh at when you're old" Will Rogers |
#3 |
I've only got the overdrive and love my choice because it preserves the 1928 driving experience in terms of gear changing, while taking the pressure off when I look in my rear view mirror for other cars that might be itching to pass. I like this difference between our cars and those with more modern gearboxes. I never intend to get the synchro.
#4 |
Overdrive, Had the same choice to make and made it right i believe
A7191-Sport Coupe 29 Roadster 29-Town Sedan 29-Original Special Coupe |
#5 |
I have a car with both synchro gearbox and O/D. Love it! I also have a couple with O/D and standard g/box. I think if I could have only one, that is what I would do. The big gap between 2nd and 3rd in the standard coghouse can be dealt with by using high 2nd and I've mastered the art of changing both with the one action. I might have to relearn that when I put a cable shift on the O/D.
When all is said and done, more is said than done. That's why we judge people on what they do, not what they say. I sometimes wonder what happened to the people who asked me for directions. If I am not in trouble, I've done something wrong. |
#6 | |
#7 |
cable shift, that is old school. Mitchell is the only way to go 6 gear syncro
#8 |
For me, I weighed all the above options and ultimately settled for the Ford RTS 4-speed all synchro OD transmission. I have no regrets with that decision. YMMV. I have not driven either of the Mitchell options, so I have no real basis for comparison.
#9 |
The overdrive, without question. It provides for much better driving if you go on tours or drive your car great distances, especially on freeways. The only advantage I can see the synchronous transmission offers is the need not to double clutch. I don't have a problem double clutching I have driven a Model A so much I don't even think about it. I don't see it as being cost affective.
I have heard a number of guys comment that they installed the trans so that their wife can drive the car. That strikes me as somewhat demeaning. They are saying their wife is not cable of learning the simple procedure of double clutching. Tom Endy |
#10 |
My decision which to install this winter was made for me. Neither!!! I had decided to have Larry install the syncro trans. I take two lane secondary roads always and I'm in no hurry to get anywhere but, I had a shock go out so, new shocks and four new tires, since one showed a bubble and the others are cracking, is on the list this winter but next winter, I hope it to be the trans.
#11 |
Overdrive, or at least for less money a 3.27 ring and pinion.
I think Carl has the best choice with his 4 speed Ford overdrive tranny. |
#12 |
It's not an "either/or" thing. Like Carl said, do the Ford RTS (F150) 4 speed OD. You get a full synchro trans AND an OD. You get to keep the enclosed drive line. You can also do it with an S10 T-5, but it's a more invasive project.
http://www.fordbarn.com/forum/showth...5594&showall=1 http://www.fordbarn.com/forum/showth...4863&showall=1 I'll be at the Turlock, CA, swap meet the end of the month. There is a guy there that sells the conversion kit. I'll pick one up for you.
All steel from pedal to wheel |
#13 |
I think the OD is the best choice, I have 3 with the OD and am happy with the setup.
#14 |
Tom Endy, the syncro trans does have the advantage of better gear ratios too.
Do any of the Ford 4 speed conversions install without changing some other aspect of the car? Seems they all require at least modifying the torque tube and drive shaft. |
#15 |
And if I may ask ; what prices are we talking here ?
#16 | |
FYI: The Mitchel OD also requires altering the drive shaft and torque tube. (also included in their kit) It's been about 6+ years since I priced the various systems, but at that time both the Mitchell Synchro tranny/OD combo and the Ford RTS 4-speed OD were essentially the same price, both around $3K. Prices on either of these may have gone up in the meantime.
Alaskan A's Antique Auto Mushers of Alaska Model A Ford Club of America Model A Restorers Club Antique Automobile Club of America Mullins Owner's Club Last edited by CarlG; 01-17-2017 at 02:41 AM. |
#17 |
#18 |
Sounds like most of you are satisfied with the transformation, but unfortunatly nothing for my wallet.
#19 |
I love my Mitchell overdrive. I like using 3rd gear overdrive for cruising and 2nd overdrive for climbing the Appalachian Mountains along the Old National Road in western Maryland.
#20 |
I like synchro , nobody will now the deference it look totally stock
