Old 01-11-2017, 12:50 AM   #1
Art Newland
Art Newland's Avatar
Default Ignition coil specs
I'm trying to round up the parts to run an engine on a test stand, this coil was in a bunch of parts I bought from an estate sale. So thought I'd clean it up and see if it is usable. Does it look like an original Model A part? Looks like possibly a Maple Leaf... Canadian maybe? (eh?) I live only 20 minutes from the boarder so I guess it's possible. Primary resistance is 2.5 ohms, secondary is 3.155k ohms... sound about right?
Art Newland is offline   Reply With Quote
Old 01-11-2017, 01:06 AM   #2
Tom Wesenberg
Tom Wesenberg's Avatar
Default Re: Ignition coil specs
Nice find. That's the first one like that I've seen or heard about. Just be sure the metal can doesn't contact the terminals. but it looks like the bakelite material may stick up above the steel shell.
Old 01-11-2017, 01:26 AM   #3
forever4
www.fordgarage.com/pages/canadianignitioncoil.htm
Yes it is Canadian, and sought after.
Read about it in the new RG&JS Rev 4.
I would be careful not put it at risk of any damage.
It belongs on an accurate restoration.
Try Ford Garage Search
forever4 is offline   Reply With Quote
Old 01-11-2017, 06:33 AM   #4
Kevin in NJ
You do not know if a coil is useable without using a coil tester. The coil MUST be warmed up as most bad coils 'work' when cold and crap out when they warm up.
Kevin in NJ is offline   Reply With Quote
Old 01-11-2017, 07:11 AM   #5
Big hammer
Buy a new coil for your test stand, less worries when testing an engine:-)
Old 01-11-2017, 07:46 AM   #6
kenparker
kenparker's Avatar
I am with Big Hammer on this one. On a test stand you do not want any ????'s. Buy a new one and take the ????'s out of the test.
kenparker is offline   Reply With Quote
Old 01-11-2017, 10:06 AM   #7
Tom Wesenberg
I agree with Vince that this coil is too valuable to be used on a test stand and should be used on a high point restoration.
Old 01-11-2017, 11:10 AM   #8
Art Newland
Duh! I should've known to take a look at your site. Thanks for the link.
Here's a couple more pictures.
Old 01-12-2017, 01:21 AM   #9
Art Newland
A friend gave me a coil for a 50's Hudson, even the same mounting bracket!
Old 01-12-2017, 02:03 AM   #10
Tom Wesenberg
I'd guess they are both made by Autolite.
Old 01-12-2017, 11:28 AM   #11
Art Newland
The Hudson one says "Autolite" on it. I haven't put a multimeter on it yet to see how it compares electrically.
Old 01-12-2017, 11:35 AM   #12
Art Newland
BTW, what would be the best way to get the Canadian coil into the hands of someone needing it for a restoration?
Old 01-12-2017, 11:50 AM   #13
SeaSlugs
SeaSlugs's Avatar
probably the for sale section here, or ebay but that involves fees...
1929 Model AA - Need long splash aprons!
SeaSlugs is offline   Reply With Quote
Old 01-12-2017, 01:49 PM   #14
Big hammer
If you need money, then do as Sea Slugs said. If you don't need money, how about donating to a national club or museum ?
Old 01-12-2017, 02:30 PM   #15
Art Newland
I wouldn't mind donating it. I'd love to see it on a car that needs it. There is a Canadian club close by, maybe I'll contact them.
Old 01-12-2017, 02:36 PM   #16
160B
160B's Avatar
PM sent
1931 160B & 1931 68B
If you don't have time to do it right the 1st time, how do you have time to do it the 2nd time?
160B is offline   Reply With Quote
Old 01-13-2017, 02:52 PM   #17
Art Newland
The coil is headed for the Canadian Model A Ford Foundation.
