Old 12-24-2016, 05:51 PM   #1
Curt Campbell
Curt Campbell's Avatar
Default Fenders for 31 wide bed pickup?
I have looked thru catalogs and cannot find front and rear fenders for 31 wide bed closed cab pickup. Also checked Rootlieb. Are 31 car front fenders the same?
Who sells these fenders? Thank you in advance.
Curt Campbell is offline   Reply With Quote
Old 12-24-2016, 06:11 PM   #2
2manycars
2manycars's Avatar
Default Re: Fenders for 31 wide bed pickup?
Front fenders are the same.
Bill
www.brauchauto.com
2manycars is offline   Reply With Quote
Old 12-24-2016, 06:16 PM   #3
Bob C
The only rear fenders available are fiberglass. Fronts are the same as cars but
the new ones take some work to get them to fit right.
Bob
Old 12-24-2016, 06:22 PM   #4
CarlG
CarlG's Avatar
Originally Posted by foxfire42 View Post
Rears are a very tough find. As far as I know they are not being reproduced in steel. Fiberglass may be the only option until you can find some originals. I believe Snyders sell the fiberglass rears. At least you can get the fronts in steel.
If you absolutely want steel for now the only option is getting standard PU rears and have a master metal person make them wider.
Wide Bed rear fenders are narrower, not wider than standard PU rears.
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 12-24-2016, 06:29 PM   #5
foxfire42
foxfire42's Avatar
CarlG, It was a test to see if anyone was paying
attention. You passed the rear fender class 101.
foxfire42 is offline   Reply With Quote
Old 12-24-2016, 09:49 PM   #6
DougVieyra
DougVieyra's Avatar
I know that the Front Fender steel reproductions, as bought, do not fit properly - by a long shot, and has to have the steel extensively reworked.
But what about the Fibreglass reproductions? Do they fit more correctly and are they easier to install than the steel fenders?
DougVieyra is offline   Reply With Quote
Old 12-26-2016, 10:40 PM   #7
Herb Concord Ca
When I did my 31 Roadster P/U, I used fiberglass fronts and they fit like a glove, just had to drill the mounting holes. I bought Steel rear fenders and didn't have any trouble bolting them on either
Herb Concord Ca is offline   Reply With Quote
Old 12-26-2016, 10:45 PM   #8
Larry Jenkins
Look at Wescott's site. The best fiberglass fenders made.
Good enough.. Isn't.
Larry Jenkins is offline   Reply With Quote
Old 12-27-2016, 03:07 PM   #9
Charlie Stephens
I thought this ad might be interesting.
http://www.fordbarn.com/forum/showthread.php?t=175980
I know nothing about it.
Charlie Stephens
Old 12-30-2016, 09:22 AM   #10
fordrelic
I plan to make a set from standard truck fenders by cutting a section from center of fender and welding back together.
fordrelic is offline   Reply With Quote
Old 12-30-2016, 12:52 PM   #11
Barry B./ Ma.
Barry B./ Ma.'s Avatar
I used coupe/ roadster rear fenders on the huckster I did. I mounted the fenders and cut them in half, down the middle, cut the middle out (after measuring the distance they stuck out from the running board) and welded them back together.
Barry B./ Ma. is offline   Reply With Quote
