Old 12-08-2016, 02:29 PM   #1
19Fordy
19Fordy's Avatar
Default Do I I need a new starter?
20 Years ago I converted my 8BA to 12V but kept using
the 1940 6V starter. Today I pressed the starter button and engine didn't crank over on the first tap of the starter button like it always. Tried again and all I get is a "whirring sound" like an electric motor is running. Engine doesn't crank over.
Does this mean I need a new starter Bendix/spring?
Are the new high torque starters worth the money or should I
convert the old starter to 12V like Fordbarner Ed Pitts did in this thread?
All ideas welcome.
http://www.fordbarn.com/forum/showth...2+volt+starter
Old 12-08-2016, 02:48 PM   #2
V8 Bob
V8 Bob's Avatar
Default Re: Do I I need a new starter?
Years ago I ran a 6V flathead starter on 12V that resulted in harsh ring gear engagement. I started to see ring gear damage, so had the starter rebuilt for 12 V. Bendix engagement is now much less aggressive and starter looks and sounds like it should. Cost of rebuilding vs a new high torque may be a toss up, but rebuilding the stock starter is better imo, especially if you have a good rebuilder in your area.
V8 Bob is offline   Reply With Quote
Old 12-08-2016, 03:01 PM   #3
Bored&Stroked
Bored&Stroked's Avatar
Originally Posted by V8 Bob View Post
Rebuilding the stock starter is better imo, especially if you have a good rebuilder in your area.
Exactly - and they can be hard to find. We do have a good one here in Columbus, OH
Also, I like the original Bendix style setup - not the modern repop ones. I am still running a 6V starter - just rebuilt it myself as my nasty engine coughed back and bent the damn armature shaft. Argggggggggh. I did find/buy a NOS armature shaft - to keep in my stash in case I do it again! LOL
Old 12-08-2016, 03:35 PM   #4
19Fordy
19Fordy's Avatar
Ok. Thanks for the replies.
Can anyone recommend a person for rebuilding my starter
and converting it to 12V?
Old 12-08-2016, 04:39 PM   #5
Ed Pitts
Ed Pitts's Avatar
Fordy, here is a post that covered this issue. Ed
Here is a post from Ronnie with a comment from me. This works and is a lot cheaper than 185 bucks. Ed
"Take your flathead starter apart. Keep the long through-bolts and end plate with the armature and bendix. Turn the armature if required. Don't under-cut the copper bars on armature. Use the starter from 332, 352, 360, 390 or 406 c.i. Ford FE engines as the conversion starter. Disassemble the FE starter. Keep the end plate with brushes and case with field coils. Check the bushing in the end plate and replace if necessary. The wire size and number of windings on the FE and flathead armatures and they are the same.
Now is also a good time to install new brushes. Install the flathead armature into the FE case. Install the FE end plate with brushes. Put long through-bolts in starter.
You now have a flathead starter capable of cranking an engine of 300 to 400 c.i. ,up to11 to 1 compression ratio. The finished starter looks like the flathead starter and you did it yourself."
This works. I have done this for two 12 volt starter conversions. On the last one I got a rebuilt starter from O'Rileys to use the case. It was for a 1964 Ford Galaxie; 390 cu in. engine. The part # is 03-0214 and the line is ULT. Cost was $39.99 plus 20 bucks for the core. So, for 60 bucks, you can have a 12 volt starter that works great.
Ed
Ed Pitts is offline   Reply With Quote
Old 12-08-2016, 04:44 PM   #6
Ed Pitts
Ed Pitts's Avatar
Here is the starter using the later FE case. Ed
Old 12-08-2016, 04:50 PM   #7
Ed Pitts
Ed Pitts's Avatar
Here is a side by side. You take out the bottom one out of the FE case and use the top one out of your 6 volt starter.
Old 12-09-2016, 08:59 AM   #8
19Fordy
19Fordy's Avatar
Hi Ed,
I sent you 2 PM messages about finding the Galaxie starter.
Will this starter work?
http://www.ebay.com/itm/NEW-STARTER-...RYKe4Y&vxp=mtr JIM
Old 12-09-2016, 09:12 AM   #9
Kurt in NJ
Kurt in NJ's Avatar
It could be that your starter drive just has congealed oil on it, that cleaning will fix----or a bendix spring bolt broke, most starters don't come with the drive, the whir means that the starter is probably working
Kurt in NJ is online now   Reply With Quote
Old 12-09-2016, 09:18 AM   #10
19Fordy
19Fordy's Avatar
Kurt,
I am thinking the same as you.
Will remove starter and post results.
Old 12-09-2016, 10:46 AM   #11
Ed Pitts
Ed Pitts's Avatar
Jim, that one should work. All you are using is the case. Just responded to your PM's. Ed
Originally Posted by 19Fordy View Post
Hi Ed,
Old 12-09-2016, 04:43 PM   #12
chap52
chap52's Avatar
Sounds like the Bendix spring broke. Had the same adventure not long ago. You can get just the spring or the entire Bendix unit.
Like Kurt said, if it spinning it's probably just a Bendix issue.
Let us know what you find.
chap52 is offline   Reply With Quote
Old 12-09-2016, 06:08 PM   #13
12cliff23
C&G has about any starter part you need, my spring broke and had the same
issue as you.
12cliff23 is offline   Reply With Quote
Old 12-09-2016, 07:09 PM   #14
19Fordy
19Fordy's Avatar
12cliff23: Thanks for the info.
Old 12-09-2016, 08:31 PM   #15
green50
green50's Avatar
A similar thing happene to me. Starter would spin, engine wouldn't crank. The findings were, someone used an incorrect bolt on the bendix and reused the lock. The bolt wound up falling out and the bendix was just spinning on the shaft.
Gene
green50 is offline   Reply With Quote
Old 12-10-2016, 04:49 AM   #16
41LjH
41LjH's Avatar
When this happened to me I replaced the starter spring and everything is fine.
3 pedals, 3 gears, no valve-covers..
Now THAT is a hot rod !!
https://www.youtube.com/watch?v=ZmwwB34vxJE
41LjH is offline   Reply With Quote
Old 12-10-2016, 08:27 AM   #17
Walt Dupont--Me.
Walt Dupont--Me.'s Avatar
I broke the spring on my 40 and Model A years ago, I replaced them with the modern torpedo style drive, bullet proof, only 25 bucks, a little harder to install to the 8BA engine,you have to do some grinding to make it fit. Walt
Walt Dupont--Me. is offline   Reply With Quote
Old 12-10-2016, 03:19 PM   #18
4t8v8
I converted my 8BA starters to 12V using a Ford Y Block starter on one and a FE starter on the other years ago. Both work great. When my Bendix spring broke I installed a new torpedo style drive. Been working for 5 years now with no problems. As Walt said a little grinding had to be done but, to me, well worth it.
4t8v8 is offline   Reply With Quote
Old 12-10-2016, 06:19 PM   #19
jack orchard
Where can i get the torpedo drive? Thanks, jack
Proud FNG
We fixem cars. Heap Good!
jack orchard is offline   Reply With Quote
Old 12-11-2016, 09:07 AM   #20
Mike51Merc
Mike51Merc's Avatar
Ed
Now, THAT'S a nice piece of tech advice. Brilliant.
While on the subject, my buddy did a 12V conversion about 15 years ago and has replaced about 4 Bendix springs since. They last a while but eventually snap from the shock.
Mike51Merc is offline   Reply With Quote
