12-06-2016, 01:23 PM | #1 |
early v8 factory ford "dynamatic" electric fan
Hello all.
As some of you well know, Little Dearborn (only 1-1/2 miles from me) has decided to move after sixty years in the same location. I have been buying up the N.O.S. as much as i can. In the mix were multiple Dynamatic fans, fomoco part # 59A-8665. ive not seen much on these,only one that recently sold on ebay. i seem to only find that they were 46-48 only. A little insight would be appreciated |
12-06-2016, 01:29 PM | #2 |
Re: early v8 factory ford "dynamatic" electric fan
These are designed to freewheel when engine does not need the fan and to lock up and drive the fan at a specified temperature. They are controlled by a sensor in the lower radiator hose that installs through the rubber just like a heater hose fitting.
12-06-2016, 01:36 PM | #3 |
Interesting. Do they have any advantage in cooling?
Regards, Scott '47 Mercury Convertible '25 Dodge Bros. Touring Car '63 MG Midget |
12-06-2016, 01:36 PM | #4 |
Thanks. As i said, i have never heard, or seen these before, & was curious as to their function. The fans i ended up with, are all N.O.S. still in the box, all but one have all the hardware & instructions still wrapped in ford packaging.
12-06-2016, 02:06 PM | #5 |
Be certain they have the switches with them as they are impossible to find and commonly missing. I have 13 NOS dynamic fans but only one still had the switch in the box.
12-06-2016, 02:24 PM | #6 |
I once bought one with no switch...and here is how that worked out: http://www.fordbarn.com/forum/showth...ght=paranormal That really happened; if you buy one with no switch, don't count on it happening again! |
12-06-2016, 02:49 PM | #7 |
Thanks, Bruce. I suspected that was the case.
