Old 12-05-2016, 09:37 AM   #1
Ric Dean
Ric Dean's Avatar
Default 1932 Ford Model 18 drophead coupe by Carlton
Check it out
https://blog.hemmings.com/index.php/...on/?refer=news
Ric Dean is offline   Reply With Quote
Old 12-05-2016, 10:22 AM   #2
Tim Ayers
Default Re: 1932 Ford Model 18 drophead coupe by Carlton
Man, love it. The rear does look decidedly British, but it looks good nonetheless.
Old 12-05-2016, 11:50 AM   #3
34 GAZ
34 GAZ's Avatar
Note that the front axle is not the familiar "heavy" type. More visible on the Sothebys site. There,s a handfull of these one-off 1932 Fords floating around Europe in various private collections. Some British, some German ( Kellner ) BTW if i could get that money for my British '32 i would stop work tomorrow. I,m almost at the pension age now so i guess i,ll just plod along for a few more years.
34 GAZ is offline   Reply With Quote
Old 12-05-2016, 03:54 PM   #4
DavidG
DavidG's Avatar
Nor is the exhaust system anything like the original. I guess it's the low ground clearance version with the short tail pipe to asphyxiate the passengers when at idle.
Old 12-05-2016, 05:37 PM   #5
mercman from oz
mercman from oz's Avatar
Here are pictures of the 1932 Ford with the body by Carlton, as referred to in the Hemmings article. Notice that low exhaust as David pointed out.
Old 12-05-2016, 05:39 PM   #6
mercman from oz
Here is a larger photo of the 32 posted by 34 GAZ
Old 12-05-2016, 08:50 PM   #7
RalphM
RalphM's Avatar
For $175 to 250K I'd be happier with three US built 32 Fords!
RalphM is offline   Reply With Quote
Old 12-05-2016, 10:16 PM   #8
Tim Ayers
OK, now that someone pointed out something not quite right with the car, I wasn't going to say it, but I will now. It drives me crazy when I see a car like this done up "to original specs" and they go and use modern hose clamps on it, throw a cheap ass fuel filter and hang it smack dab in the middle of plain sight.
I know it's such a small thing, but jeez & cheese, take some pride and finish up all the details.
Old 12-05-2016, 11:02 PM   #9
JSeery
JSeery's Avatar
Good point. Is even the rubber hose from the fuel pump to the carb correct? Wouldn't it have been solid line?
Old 12-06-2016, 06:01 AM   #10
48-710
Gentlemen,how long did the "post generator" last ? I have a manifold, and, yes it does have the broken clamp syndrome.
48-710 is offline   Reply With Quote
Old 12-06-2016, 06:22 AM   #11
37 Cab
37 Cab's Avatar
The one pictured with no wheels must sit there all the time.. Note the running board turning green along with the driveway. Shame.
Tommy
37 Cab is offline   Reply With Quote
Old 12-12-2016, 08:34 AM   #12
OHV DeLuxe
Ford cars in this style shows up from time to time in Europe, i`ve been offered two different similar versions, 1935 and 1936, british and german, but to me they look like a nerdy combination of american and british cars, i prefer them seperate.
But very nice craftmanship both by initial builders and current caretaker.
OHV DeLuxe is offline   Reply With Quote
Old 12-12-2016, 08:47 AM   #13
rockfla
rockfla's Avatar
@OHV Deluxe
If you have pictures of the above mentioned cars, I sure would like to get copies of them and where they are? Thanks.
Old 01-02-2017, 06:06 AM   #14
OHV DeLuxe
Rockfla, i sent you a message.
