Old 12-02-2016, 07:56 PM   #1
Divco one
Divco one's Avatar
Default Wood patterns
Are wood patterns available for a 1930 Coupe?
Divco one is offline   Reply With Quote
Old 12-02-2016, 10:21 PM   #2
C26Pinelake
Default Re: Wood patterns
yes they are but there is a cost involved. Wayne
C26Pinelake is offline   Reply With Quote
Old 12-02-2016, 11:30 PM   #3
WestCoast
wood kits are available but I have not seen the patterns to make them
WestCoast is offline   Reply With Quote
Old 12-02-2016, 11:55 PM   #4
Mike V. Florida
Mike V. Florida's Avatar
Location: Florida between Sarasota and TampaSouth Florida
Nope
Old 12-03-2016, 10:03 AM   #5
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Printed paper patterns ....No, --Factory Prints ...Yes.
Just curious, do you have any of the original wood that you can pattern off of??
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 12-03-2016, 01:26 PM   #6
vern hodgson
Where do you find factory prints?
vern hodgson is offline   Reply With Quote
Old 12-03-2016, 02:09 PM   #7
BRENT in 10-uh-C
At the Benson Library.
BRENT in 10-uh-C
Old 12-03-2016, 03:44 PM   #8
Divco one
Divco one's Avatar
This is a friend that wanted to have replacement wood ready so it could be replaced over a period of time. I goggled "benson library" but nothing of value was found.
Old 12-03-2016, 04:47 PM   #9
BRENT in 10-uh-C
https://www.thehenryford.org/collections-and-research/
I will tell you upfront that each print is around $50 a piece, --and I would venture a guess there is 20-25 prints that will be needed. In addition, you will need to go thru the Body Parts Book and find the appropriate part number for the piece you are looking for. In some cases, the part number in the book is an assembly drawing which means you will then need to look on that print to find each of the subcomponent prints that makes up the wood piece. Speaking from experience, this can take hours as you also have the possibility of revision changes and engineering notes that must be looked at to determine what is correct for your friend's car.
BRENT in 10-uh-C
Old 12-03-2016, 05:17 PM   #10
C26Pinelake
i had a man trace me a partial set from a disassembled coupe and he charged me $50 per piece and it was not complete. Wayne
