11-16-2016, 04:37 AM | #1 |
33 Steering Box
Hi Barners, I have spent many hours trying to get my 33 steering to an acceptable standard. After several attempts to restore the box & adjust as per green book I decided enough was enough.
I contacted Flathead Ted and ordered his modified boxes that he was advertising. Fitted the box and off for a trial run. The steering was so light that I nearly wiped out the back mudguard backing it out of the shed. I have always enjoyed driving the 33 but now it is such a pleasure. Thank you Ted. Kpar |
11-16-2016, 06:36 AM | #2 |
Re: 33 Steering Box
Any pictures? How much? Don't see them on his web site? Thanks
11-16-2016, 08:18 AM | #3 |
Re: 33 Steering Box
Interested in details?
[FONT=Comic Sans MS] |
11-17-2016, 01:18 AM | #4 |
Re: 33 Steering Box
This is a 32 Box I have them in 32 to 34 in Left and right , F1 type internals, Limited supply until production ramps up . Email for pricing ,Ted
[email protected] |
07-22-2017, 04:34 PM | #5 |
Re: 33 Steering Box
Can we get an update on this from Ted?
07-23-2017, 04:33 PM | #6 |
Re: 33 Steering Box
07-23-2017, 05:52 PM | #7 |
Re: 33 Steering Box
As mentioned before I'm happy with the box.
One thing to keep in mind is the different shaft lengths & location of steering lock tab. Maybe send your old shaft to Ted. Kpar |
07-23-2017, 08:47 PM | #8 |
Re: 33 Steering Box
Part of what I have been doing is working out the steering shaft specs ,so I can supply the complete unit ,at this point I am not supplying or drilling the steering lock tab ,The lengths are 33-34, 42".
32 -41" Model A 44-1/8 |
07-24-2017, 12:56 AM | #9 |
Re: 33 Steering Box
Ted is not the 33 different to the 34 with the different ratio?
Lawrie |
07-24-2017, 05:36 AM | #10 |
Re: 33 Steering Box
Lawrie is correct there are two ratios in 33-34
Ran into that truck by to rebuild. Parts not interchangeable |
07-24-2017, 07:50 AM | #11 |
Re: 33 Steering Box
Any plans to do a 36 box?
07-24-2017, 02:42 PM | #12 |
Re: 33 Steering Box
The parting line between 13 to 1 and 15 to 1 ratios was a running change in the '33 model year. Also early '33 steering shafts and tubes are shorter than the later '33 (and all '34) shafts and tubes.
07-24-2017, 03:28 PM | #13 |
Re: 33 Steering Box
The 33 &34 will be standard ised at 15 to 1 .The lock collar can be fitted later to suit. I plan to do a 35 /36 at some point .I think that early 33 may have used the 32 shaft at 31" but I can do any required .Ted
07-25-2017, 06:25 AM | #14 |
Re: 33 Steering Box
Is lock to lock the same for the 13-1 as the 15-1?
07-25-2017, 07:01 AM | #15 |
Re: 33 Steering Box
What is the difference between your 15-1 34 and a stock 15-1?
07-26-2017, 12:22 AM | #16 |
Re: 33 Steering Box
With mine you have a roller like a 37 to 40 rather than a peg ,Also with a 15 to 1 you get maybe half a turn more ,Ted
E mail . [email protected] Last edited by FlatheadTed; 07-26-2017 at 04:49 PM. |
08-16-2017, 05:36 AM | #17 |
Re: 33 Steering Box
Ted,
Do you envisage ever making your new steering box for a Model A? And in RHD? Thanks for making the 32 and 33-34 boxes available. |
08-16-2017, 08:04 AM | #18 |
Re: 33 Steering Box
I would be interested in having one of your modifications for my 36.
08-16-2017, 03:26 PM | #19 |
Re: 33 Steering Box
Hi Mark The last pictures I posted (not a clear one ) you will note the lower one is a RH 32 with the model A chassis mount ,
08-16-2017, 03:29 PM | #20 |
Re: 33 Steering Box
We are working on the 35 /36 one PM sent Ted
