Old 11-08-2016, 01:12 AM   #1
Georg_Becker
Default Different Drive Shafts
Hello everybody,
I have determined that the drive shafts of my 1930 Tudoor are different in length. For a shaft the thread 1/2 "is longer than the other. Does anyone have an explanation for this?
Greetings from Germany
Georg
http://www.bilder-upload.eu/show.php...1478585941.jpg
http://www.bilder-upload.eu/show.php...1478585897.jpg
Georg_Becker is offline   Reply With Quote
Old 11-08-2016, 12:16 PM   #2
Bob C
Default Re: Different Drive Shafts
I measured one I have and from the end of the taper to the end of the
shaft is about 30mm.
Bob
Old 11-08-2016, 12:22 PM   #3
SeaSlugs
SeaSlugs's Avatar
SOmetimes really stuck drums people really crank on the puller that pushes on the end of the shaft and smack it hard. Usually 1 or 2 whacks gets it free. If not they try more and more and tightening more and more and I have seen it crack the end of the shaft since the cotter pin hole is there. I think someone did this to your axles in the past and ground it off. Is there a cotter hole on the short shaft?
OR im not sure but the early cars had no seperate emergency brakes and had slightly different drums and wheels, the axles could be shorter couldnt they? (they are on AA's)
1929 Model AA - Need long splash aprons!
SeaSlugs is offline   Reply With Quote
