Old 11-07-2016, 07:08 PM   #1
Ritzy1
Ritzy1's Avatar
Default Brake system advice request
So, I'm building a '48 Ford Tudor Sedan. Thought I was going in the right direction by going with 4 wheel disk brakes. I found a disk-brake-equipped 8.8" rear axle from a '94 Mustang GT and got it mounted with a Posies kit. I ordered custom backspaced Gennie wheels from Wheel Vintiques so the P235/65R16 tires would tuck inside the wheelwells. I have a disk brake kit that will go on the dropped solid axle when I get to the front end.
Today I called ECI to ask about their kit to adapt a dual master cylinder to the original frame that would also allow me to use the original clutch with the S-10 T-5 trans. Ralph there told me that combination will not work without a booster. I have not seen a way to add power brakes to the original x-frame while keeping the original clutch, so now I'm panicked.
Ralph recommended I go with a drum brake in the rear. Does anyone make a bolt-on drum brake kit for an 8.8" Ford? Does anyone have another cost-effective recommendation that would hopefully allow me to utilize the stuff I've already bought?
Thank you in advance. Dave
Ritzy1 is offline   Reply With Quote
Old 11-08-2016, 08:31 AM   #2
JSeery
JSeery's Avatar
Default Re: Brake system advice request
Not sure what the 8.8 you are using is out of, but the Fox body mustangs/cougars used both disc and drum brakes. I have switched them back and forth. So stock drum brake parts should bolt on (there is a bracket you have to remove that is welded to the axle housing if I remember correctly). There should be information online about this modification. The HAMB might be a good source of information.
Old 11-08-2016, 09:26 AM   #3
Ol' Ron
Ol' Ron's Avatar
I havr 4 wheel disks on my truck and they work fine, with no power assist. You just have to push harder. I was told I could change to the Green pads to improve the pedal pressure. I use a Corvet MC
Old 11-08-2016, 09:26 AM   #4
Kurt in NJ
Kurt in NJ's Avatar
There are seperate boosters that are plumbed into the brake pipes that can be mounted most any place, servo booster---
http://dave78chieftain.com/HydroVac_brakes.html ---gives you the idea
Old 11-08-2016, 08:38 PM   #5
Ritzy1
Ritzy1's Avatar
Thanks for the info everyone. J, you are correct about The HAMB. After I posted this here I posted it over there and could not figure out how to delete this thread. I was hoping that perhaps I might get different advice from each site, but I realized that this site is not normally for this type of question.
Old 11-09-2016, 03:12 AM   #6
Marvin/TN
Send a message via AIM to Marvin/TN
Check with Chassis engineering They have a bolt on kit that uses a Pinto Double Diaphram
brake booster that uses the original brake pedal. I used a Corvette M/C from No Limit Engineering that has been converted to a remote fill. I can't post pics here but I can E. Mail you some PICs of my 46 Chassis if you would like for me to.
Marvin/TN is offline   Reply With Quote
