Old 10-30-2016, 08:38 PM   #1
ButchRed33
Default block prep
I took my '32 B block in to a place that bakes the gunk off the blocks, etc.
It had been in storage for a long time, so I put axle grease on mains, cylinders, etc. since things tend to rust where I had to store them.
Now the gunk is baked off, but I have a greasy block. I'm worried about the water jackets and oil passages. Is it possible to soak it gasoline, or ?????,
and use brushes to clean the passages, or is there a better, more foolproof way? I'm a stickler for a clean block, so as to have no silly cooling or debris problems.
Any suggestions?
ButchRed33 is offline   Reply With Quote
