Old 10-27-2016, 11:28 PM   #1
Ramjet47
Ramjet47's Avatar
Default Tail light loom run 1937 RHD
Does any member have a drawing or a photo of the tail light loom run on a 1937 RHD 5window coup'e, especially in the area of the central chassis cross member box.
Ramjet47
Ramjet47 is offline   Reply With Quote
Old 10-28-2016, 12:24 PM   #2
Anton Voycheck
Anton Voycheck's Avatar
Default Re: Tail light loom run 1937 RHD
Tail light harness (or body harness) runs from the headlight switch box junction back along the inside of the frame rail all the way back to the cross member in front of the fuel tank. The harness splits at this point for the opposite taillight and the fuel gauge wire.
Anton Voycheck is offline   Reply With Quote
Old 10-28-2016, 11:29 PM   #3
Ramjet47
Ramjet47's Avatar
Thanks Anton for your response. I can see how the loom runs along the inner lower horizontal flange of the forward and rearward chassis diagonal cross members but I can't figure out how the loom passes the centre chassis box area. Does it exit the forward chassis diagonal cross member through the hole in the vertical web just rear of the brake and clutch pedal module and then along out side of the centre chassis box and then pass back through the hole on the rear diagonal vertical web behind the brake cross shaft?
Old 10-29-2016, 01:04 AM   #4
FlatheadTed
FlatheadTed's Avatar
Some models run along the x over the rear engine mount ,hooks up to the stop switch then meets the side rail near the kick up .Ted
http://www.flatheadted.com
Flathead Ted brake Floaters ,
