Old 11-13-2010, 08:33 PM   #1
leebros60
Default steering box id
can anyone tell me the difference (if there is a difference) between a f1 and a f100 steering box. thax Lee
leebros60 is offline   Reply With Quote
Old 11-13-2010, 11:08 PM   #2
Strick
Strick's Avatar
Default Re: steering box id
have the same question. this might help. what do i have here, f1 or f100?
Strick is offline   Reply With Quote
Old 11-13-2010, 11:44 PM   #3
gmc1941
gmc1941's Avatar
F-100 it's not a F-1
1939 Fordor Deluxe
1939 Ford Coupe Std
1940 Ford pickup
Nothing in life is to be feared; it is only to be understood.
gmc1941 is offline   Reply With Quote
Old 11-14-2010, 05:43 AM   #4
Mart
Mart's Avatar
The steering box in the pic looks like an F1 with a modified flange welded on.
When is position, the F1 worm is BELOW the pitman shaft, the F100 is ABOVE the pitman shaft.
Here is a shot of the F1 box (with modified flange) in my 32 Sedan. Note the worm is underslung - ie below the pitman shaft. You will also note the stock 32 pitman arm fits the F1 box.
The F100 box has a bigger shaft and the pitman arm has a clamp bolt.
Mart.
Edit: I see the filler plug location is slightly different. From this I would say the box shown is not F100 for sure, but is similar to my F1 box. From the orientation of the bolts, it may have been made for a 33/34 rather than a 32.
