Old 09-02-2016, 04:09 PM   #1
Ken Anderson
Ken Anderson's Avatar
Default Manifold Vacuum Leak Question
I am trying to help a friend with his 30 Model A. How much of a vacuum leak does it take to have a significant third gear power loss? Car cranks right up and does OK if 1st and 2nd but as soon as you go into third it looses power. New distributor, timing set by test light, good carb - sudden onset problem.
Ken Anderson is offline   Reply With Quote
Old 09-02-2016, 04:19 PM   #2
DJ S
DJ S's Avatar
Default Re: Manifold Vacuum Leak Question
Spray carburetor cleaner where the manifold meets the block. If the idle increases, you have a vacuum leak. Try tightening the nuts (not too tight). If this doesn't solve the issue, remove the manifold and check for straightness.
DJ S is offline   Reply With Quote
Old 09-02-2016, 04:26 PM   #3
Mitch//pa
If it is hitting on all 4 at idle and running good until 3rd gear I would look else where..
Could be timing, fuel starvation, weak spark, restricted exhaust etc...
Old 09-02-2016, 04:31 PM   #4
Safewiz
Safewiz's Avatar
x2 Mitch sounds correct. Doesn't sound like Manifold problem.
Coral Springs Florida
Safewiz is offline   Reply With Quote
Old 09-02-2016, 04:43 PM   #5
Step-down
Step-down's Avatar
Check color of the plugs .
"I can't cry as long as I know the Lord has risen "
Step-down is offline   Reply With Quote
Old 09-02-2016, 09:12 PM   #6
Jacksonlll
Jacksonlll's Avatar
Send a message via ICQ to Jacksonlll
Make sure your points are not floating due to a broken spring. Just feel the spring load with your finger. Should be pretty tight.
Jacksonlll is offline   Reply With Quote
Old 09-02-2016, 10:08 PM   #7
ddweave
ddweave's Avatar
It sounds like it's running lean. Have you tried opening the GAV a bit - or pulling the choke?
Doug in Waterloo
ddweave is offline   Reply With Quote
Old 09-02-2016, 10:40 PM   #8
MikeK
MikeK's Avatar
Fuel starvation. Restrictive crud somewhere or perhaps fuel line pushed too far in at carb connection? If it is a stock Zenith carb try removing the single bolt that holds the bottom half. With the bottom half removed place a pan underneath it and open the gas valve. If you do not get at least 1 pint per minute you have a starvation problem.
Of course you do this test with the engine/exhaust cold and outside with an assistant and a water hose handy. Expect to slobber some fuel.
MikeK is offline   Reply With Quote
Old 09-03-2016, 07:58 AM   #9
Ken Anderson
Update: Decided to remove the manifold. Took the front nut off by hand, the stud came out with the rear, middle two seemed tight, gasket was split top to bottom between #4 port and rear intake. Have ordered new studs and gasket from Mike's. Even if this doesn't fix the problem it's still a fix that needs to be made. My buddy is upset enough with the way the car has been running that he is threatening to sell her and I would hate to see that happen - everything else is good and I need another "A" to run around with!
Old 09-03-2016, 08:48 AM   #10
Mitch//pa
If the intake manifold was sucking air past the gasket , then it was not running properly at idle either
thanks for the update
Old 09-03-2016, 11:38 AM   #11
Brentwood Bob
Hope you put a straight edge on the assembled intake and exhaust to see how straight the assembly is flush to the block.
Bob
Brentwood Bob is offline   Reply With Quote
