09-01-2016, 11:35 AM | #1 |
No Taillights
I have break lights on both taillights. But I don't have parking or running lights on either back tail light. Where should I start on checking the wires for a cut or something.
Thanks, Tom..... |
09-01-2016, 12:01 PM | #2 |
Re: No Taillights
http://www.sacramentocapitolas.org/a...wiring-diagram
The diagram above should help. You'll have. To trace out where you've lost voltage.
-Mike Late 31' Ford Model A Tudor, Miss Daisy I don't work on cars --I'm learning about my Model A. Cleveland, Ohio |
09-01-2016, 12:06 PM | #3 |
Re: No Taillights
Check for an un-plugged wire, inside the head light switch.
Bill W.
09-01-2016, 12:09 PM | #4 |
Re: No Taillights
I always start at the end of the juice which would be the taillights and would use a testlight
Ck where the cross over harness connects in from the l/r tail harness Last edited by Mitch//pa; 09-01-2016 at 12:19 PM. |
09-02-2016, 11:00 AM | #5 |
Re: No Taillights
Thanks guys for the suggestions. I am going out to the garage and play with it for a while and see if I can come up with something. Will let you know what I find out when I do.
Thanks..... |
09-05-2016, 11:56 AM | #6 |
Re: No Taillights
Tom..... |
09-05-2016, 02:39 PM | #7 |
Re: No Taillights
It sounds like it is one common wire. Wayne
