Old 11-12-2010, 09:28 PM   #1
randy randolph
randy randolph's Avatar
Default popout help
hi i have a nice looking orginal popout switch with no key .i do have a blank key. can i take it to a lock smith all in one peace .or do i have to take it apart somehow.thanks randy
randy randolph is offline   Reply With Quote
Old 11-12-2010, 09:41 PM   #2
Tom Wesenberg
Tom Wesenberg's Avatar
Default Re: popout help
You can take it in one piece, but you should just read the number on the lock cylinder and call A&L and they will cut you a new key. Then you can have any key cutter duplicate your blank to the new key.
I can post a picture of the number if you need it. What year is the popout? Is it the first style for the oval speedometer instrument panel, or it it the later style, with a steel plate crimped in place on the back of the cylinder? The later style is used with the round speedometer instrument panels.
Old 11-12-2010, 10:52 PM   #3
randy randolph
it has a plate crimped on the back. please post picture .thank you
Old 11-13-2010, 08:23 AM   #4
Tom Wesenberg
Here's a picture showing the number (A1538) on the original popout used with the round speedometer.
For the popout used with the oval speedometer you have to look on the side of the cylinder.
Here's a picture of the popout used with the oval speedometer showing the number (A888) on the side. Notice that someone has used a 1930-1 key in it. I'll call A&L and have the correct key cut, and keep this key for a spare.
Old 11-13-2010, 10:09 AM   #5
Philip McCarty
I am unfamiliar with A &L do they have an address and phone number. Thanks
Philip McCarty is offline   Reply With Quote
Old 11-13-2010, 10:23 AM   #6
tuneman
tuneman's Avatar
I belive this is the number and address for a&l
806-693-2620
Box 301
Canton, CT 06019
tuneman is offline   Reply With Quote
Old 11-13-2010, 01:05 PM   #7
Philip McCarty
Thank you. That gives me my answer.
Old 11-13-2010, 03:18 PM   #8
randy randolph
thanks tom for your help !!!!!!!!!!!!!!!
Old 11-13-2010, 04:11 PM   #9
Tom Endy
Tom Endy's Avatar
Best bet is to send it to "The Key Guy". He has been around the hobby for years and knows all about pop-outs and keys and can provide an original blank. His prices are reasonable and he is a nice fellow to do business with.
Cal Allen
Chandler, AZ
480-892-0456
Tom Endy
Tom Endy is offline   Reply With Quote
Old 11-13-2010, 05:09 PM   #10
Kevin in NJ
What are the odds the wire in the switch cable is good?
The wire usually wear though right were the cable bends on the engine. At least on all the ones I have had apart.
Kevin in NJ is offline   Reply With Quote
Old 11-13-2010, 06:16 PM   #11
Joop
Joop's Avatar
Randy.
What is the number on the unit?
I can cut you a key.
Joop
Joop is offline   Reply With Quote
