Old 08-26-2016, 01:30 PM   #1
36tudordeluxe
36tudordeluxe's Avatar
Default Drill speed for flex hone?
The directions that came with the FLEX HONE recommend 500-800 RPM; my Milwaukee drill is rated at 400 low speed, 1500 high speed but I don't know if these speeds are under load. My question is do I use the low or high speed setting?
36tudordeluxe is offline   Reply With Quote
Old 08-26-2016, 01:57 PM   #2
Capt Kirk
Capt Kirk's Avatar
Default Re: Drill speed for flex hone?
I'd use the low speed. If you use high, you're gonna feel like you're churning butter the old fashion way!
35 Ford Cabriolet
56 Chevy Pickup
63 VW Bug
Empty wallet
Capt Kirk is offline   Reply With Quote
Old 08-26-2016, 01:59 PM   #3
51 MERC-CT
51 MERC-CT's Avatar
The lowest speed the drill will run, regardless of ratings or settings.
Old 08-26-2016, 02:06 PM   #4
36tudordeluxe
Okay, low speed it is, thank you.
Old 08-26-2016, 02:16 PM   #5
36tudordeluxe
How does this look, haven't washed the cylinder with warm soapy water yet?
Old 08-26-2016, 03:01 PM   #6
Ronnieroadster
Ronnieroadster's Avatar
You dun good
Ronnieroadster is offline   Reply With Quote
Old 08-26-2016, 03:15 PM   #7
36tudordeluxe
Originally Posted by ronnieroadster View Post
you dun good
thank you!
Old 08-26-2016, 03:15 PM   #8
Ronnie
Ronnie's Avatar
Lookin like a pro job from here. After the final clean give it a wipe with oil to preserve it until assembly.
R
Ronnie is offline   Reply With Quote
Old 08-26-2016, 03:16 PM   #9
BUBBAS IGNITION
BUBBAS IGNITION's Avatar
Also depends on the lube used .........slow speed with marvel is usually pretty good.....
If it Makes Spark, we do it !!!!
www.bubbasignition.com
[email protected]
BUBBAS IGNITION is offline   Reply With Quote
Old 08-26-2016, 04:23 PM   #10
36tudordeluxe
Going to give it a bath and then wipe it down with oil and wait for the rings to get here. Thanks for the help guys.
Old 08-26-2016, 10:47 PM   #11
Ronnie
Ronnie's Avatar
Carry on and keep smiling it was quite easy wasn't it.
R
Old 09-28-2016, 10:11 AM   #12
Ronnie
Ronnie's Avatar
What is the latest update on your repair?
R
Old 09-28-2016, 11:00 AM   #13
36tudordeluxe
Got sidetracked with minor issues on the '36 and about to button that up in a few more days. Got the Hastings rings from my machinist. Looks like the gaps on the rings will be about .015, little larger than ideal but should be okay?
Old 09-28-2016, 12:09 PM   #14
Bored&Stroked
Bored&Stroked's Avatar
Looks like you're getting it done - nice work! The ring gap of .015 will be just fine - just take a file to break the sharp corner/edge on both sides of the gap (keeps them from scratching the bore). You only need to just barely take the corner off - don't file away on it!
Old 09-28-2016, 12:32 PM   #15
Ronnie
Ronnie's Avatar
Things are good remember the ring gaps are stated as minimum gaps not max .015" will be great as already stated. How did your glaze break and cleanup turn out or need I ask?
Good to see another fine home grown project move along.
R
Old 09-28-2016, 09:59 PM   #16
36tudordeluxe
Will carefully file corner/edge on the rings.
Should be able to get to this in the next day or two.
Appreciate the help and encouragement.
Old 09-28-2016, 10:08 PM   #17
Ronnie
Ronnie's Avatar
Just use some 320 paper on a flat file to do the job but it really isn't required if you didn't file fit the rings.
R
