Go Back   The Ford Barn > To The Editors > Questions & Suggestions
Old 08-23-2016, 07:29 AM   #1
1620
Unhappy '47 Flathead won't keep running
I have new 6 volt coil, new 6 volt fuel pump, new condenser,new fuel lines,and cleaned carb and calibrated float level
Now I am having to pull my car about 200 or 300 feet to start and it runs great for about a minute or two a land then it dies as if it is running out of gas
HELP me please
1620 is offline   Reply With Quote
Old 08-23-2016, 10:32 AM   #2
roundvalley
roundvalley's Avatar
Default Re: '47 Flathead won't keep running
Had similar problem with a 6V fuel pump. When gas tank was full , it would run well. When half tank it would not run for long. Fuel pump is a pusher and was mounted high and forward towards the engine. Moved pump back toward the tank and lower. This solved the problem. I think the pump was not pulling out of the tank when down to half?
roundvalley is offline   Reply With Quote
