Old 08-19-2016, 04:15 PM   #1
cuzncletus
cuzncletus's Avatar
Default head gasket problem?
Assembling my 59AB I noticed that both head gaskets were the same. I'm using Fel-Pro fiber gaskets with the stamped fire ring. I've always assembled motors with the print side up. In doing this with the Fel-Pro's, one side ends up with the print side down and the wider stamped fire ring away from the block and towards the head.
I just wanted to make sure everything was right before I torqued the heads down.
cuzncletus is offline   Reply With Quote
