Old 08-18-2016, 10:05 AM   #1
Jonnyenglish
Default Drag link joint
I am away from my car at the moment so cant check but trying to get a list together of parts to order. Its a 39.
Can anyone confirm if the joint where the drag link joins the pitman arm is replaceable or do you have to buy a complete draglink?
Thanks
Jonnyenglish is offline   Reply With Quote
Old 08-18-2016, 10:53 AM   #2
Terry,OH
Terry,OH's Avatar
Default Re: Drag link joint
Original is not replaceable it has just one clamp at the steering arm side. The Ford aftermarket made in 41 has a replaceable joint with two clamps I believe at the pitman arm side. You may want to look.
Old 08-19-2016, 07:30 AM   #3
Jonnyenglish
Ok thanks, il look.
