Old 08-09-2016, 12:29 PM   #1
cranium
Default T5 to torque tube adapter
Here is an adapter I make to put a jeep t5 behind your flathead and keep your torque tube. The one thing you do have to do is drill and tap the end of the jeep t5 output shaft. I have a few made up if anyone is interested. PM me for more details.
cranium is offline   Reply With Quote
Old 08-09-2016, 01:46 PM   #2
V8COOPMAN
V8COOPMAN's Avatar
Default Re: T5 to torque tube adapter
Are you KATO KINGS on the HAMB? DD
Click Links Below __
T5 W/TORQUE TUBE
Old 08-09-2016, 02:26 PM   #3
cranium
Yes.
Old 08-09-2016, 03:32 PM   #4
PeteVS
PeteVS's Avatar
How much longer than the traditional Ford 3 speed is the T5 with the adaptor? (How much does the torque tube / drive shaft have to be shortened?)
Don't never get rid of nuthin!
PeteVS is offline   Reply With Quote
Old 08-09-2016, 03:34 PM   #5
V8COOPMAN
V8COOPMAN's Avatar
Yes.
I believe this pic shows the parts you make for the Jeep version. I've found that the guys over on the Model A Forum seem to show much more interest in the "T5 / torque tube" set-up than the guys here on the V8 Forum. DD
T5 W/TORQUE TUBE
Old 08-09-2016, 03:41 PM   #6
V8COOPMAN
V8COOPMAN's Avatar
We figure the Jeep version is just a little over 7" longer than an old Ford 3-speed. The T5 BOX is 9-1/4", and the Jeep 4X4 HOUSING is exactly 6" long. Compare that, plus 1/2" for his adapter, to the old Ford box length. DD
T5 W/TORQUE TUBE
Old 08-09-2016, 03:44 PM   #7
Mart
Mart's Avatar
Interesting photo. Nice conversion. The adaption of the shaft is always the more hard to achieve part. With the V8s being a little more driveable over longer distances than an A might be part of the reason for an increased interest amongst the A crowd. Not wanting to cut a 32 crossmember is also a big factor.
Mart.
Old 01-08-2017, 06:12 PM   #8
gasolinedeniz
which transmision do i exactly need for this conversion ?
gasolinedeniz is offline   Reply With Quote
Old 01-08-2017, 07:15 PM   #9
V8COOPMAN
V8COOPMAN's Avatar
gasolinedeniz.........Most any T5 main case can be used, but I prefer the Chevy-based cases as they are easier to adapt to a FLATHEAD engine...in my opinion. Then, you'll need a 23-spline mainshaft, as well as the tailshaft HOUSING along with the corresponding short shift rod for that tailshaft housing from an '82-'86 Jeep 4 X 4 with T5 trans.
Before you go out looking for parts, you would do well to know your rear end ratio, an approximate diameter of your REAR tires, and what your intended use for the car is. There are some almost USELESS gearsets that are available in some of these T5s, although the gearsets will ALL fit any T5 main case. Try to get it right the first time with the correct gearset. Do yourself a huge favor and read the thread that I posted covering this subject from start to finish. Pay particular attention to posts #3 and #4, although posts #1 thru#7 tell the entire story. They further explain some of the particulars in choosing T5 parts necessary for this adaptation. Click link below, or click on the "T5 W/TORQUE TUBE" at bottom, left of THIS post. Come back with any questions you may have. DD
http://www.fordbarn.com/forum/showth...T5+TORQUE+TUBE
T5 W/TORQUE TUBE
Old 01-09-2017, 02:08 PM   #10
gasolinedeniz
thank you :-)
Old 01-09-2017, 02:08 PM   #11
gasolinedeniz
i gonna read your article now :-)
Old 01-09-2017, 02:19 PM   #12
Ol' Ron
Ol' Ron's Avatar
Nice looking modification. Pau attention to what Coop says.
Old 06-13-2017, 02:24 PM   #13
cranium
I have a few more adapters available. PM for more info.
Old 06-13-2017, 02:54 PM   #14
JSeery
JSeery's Avatar
I agree with Coop on the Chevy case except it is possible to use a Ford pattern T5 adapter with a hogshead (my preference) and the Ford mustang T5 tend to have the better gear ratios from the get-go. If you are wanting to use the alum bellhousing then the Chevy pattern T5 is the way to go.
Old 06-13-2017, 03:15 PM   #15
V8COOPMAN
V8COOPMAN's Avatar
JSeery is pretty sharp about these old T5 boxes and their guts. Keep in mind here that no matter which trans is used (Chevy or Ford) for this adaptation/project, it's gotta be a NWC gearset to be compatible with the Jeep parts, as that 4X4 trans was only produced in NWC form. The early Chevys and Ford T5s were BOTH available with the 2.95 1st gear ratio that JSeery and I continue to promote. The neat point that I believe makes the decision a little "cleaner" is that using the Chevy box along with the 26-spline input shaft (2.95 1st) does not require the thick aluminum adapter plate between the Chevy transmission case and the aftermarket bell adapter. I BELIEVE that all the Chevy 26-spline input shafts are the same length. It seems like the Ford input shafts can be of varying lengths, requiring different thickness aluminum adapters........Seery will know the answer to THAT with certainty. DD
I just think this combo using the Chevy case, and WITHOUT the aluminum plate, is about as clean as it gets.
T5 W/TORQUE TUBE
Old 06-13-2017, 03:30 PM   #16
JSeery
JSeery's Avatar
Both the Ford and Chevy input shafts come in different lengths, but it might be a little less common among the Chevy line. I was not familiar with the jeep being NWC only. That would make the Chevy a better option (maybe) as the NWC Fords tend to have the long input shafts.
Coop, that is a clean setup!
Old 06-13-2017, 05:52 PM   #17
Russ/40
Russ/40's Avatar
You guys ought to put together a "T5 Bible" if it hasn't already been done. Id have to read it 5 times before I understood it.
Russ/40 is offline   Reply With Quote
Old 06-14-2017, 05:34 AM   #18
Mart
Mart's Avatar
Amen.
Old 06-14-2017, 05:57 AM   #19
47Sooner
47Sooner's Avatar
Great information. I'd love to do one of these in my 37 pickup, especially since it came with no engine and trans. I enjoy driving my 36 pickup around town but finding those gears can be a challenge some times, but I'm getting better.
47Sooner is offline   Reply With Quote
Old 06-14-2017, 09:33 AM   #20
Kahuna
Kahuna's Avatar
Coop
As I recall, Gene Sanders (Model Engineering: We are only 32) makes a nice aluminum adapter for Flathead to T-5.
I have one of his for Flathead to Toploader 4 speed. Nice product.
Jim
Kahuna is offline   Reply With Quote
