Old 07-26-2016, 07:11 PM   #1
CP
CP's Avatar
Default resistor for 12v with original 1935 inline
Hello all once again,
just realized there is an original resistor under the dash that I never knew was there.
From other posts....i found this "14.2V / 3.5 Ohms = 4 Amps"
I'm running 12volts 1948 flathead with a Mallory electronic distributor.
Mallory paperwork requires ballast resistor. I'm running a 12 volt coil. and I have a ceramic resistor between the battery and the "+" of the coil. Plus the resistor I did not know was there. Lately, when the engine gets "hot"....it is difficult to start.
wondering 2-questions...
1. what is the "stock" resistor in ohms (original 6v system) 1935
2. from what ive read, 4 amps is what we want for any engine (6v or 12v).
I know the resistance changes with "heat"...so I'm thinking the ceramic coil I have is "too much" yet i do not know how to test hot or cold.
any thoughts? I am not knowledgeable in this...
I'm thinking I want to keep the original resistor as is...say it is 1.5 ohms...I will then purchase a 2.0 ohm ceramic resistor and be "all set" no?
I saw another post that napa has many ceramic resistors available and i think 1.8 ohms was the most i could get..
If that is the case...is it better to have more resistance or less? I'm confused.
CP
CP is offline   Reply With Quote
Old 07-26-2016, 07:37 PM   #2
paul2748
paul2748's Avatar
Default Re: resistor for 12v with original 1935 inline
Are you running a 12 volt, negative ground system?
48 Ford Conv
56 Tbird
54 Ford Victoria
Old 07-26-2016, 07:46 PM   #3
CP
CP's Avatar
yes
Old 07-26-2016, 07:55 PM   #4
BUBBAS IGNITION
BUBBAS IGNITION's Avatar
Original resistor is .6 ohms.... Leave it as is and use a 1.5 ohm coil. Should be fine. Total 2.1 would be approx six amps, Mallory cuts out at 8 amps with current limiting .
Napa. IC 12 SB is ac1.5 ohm coil
If it Makes Spark, we do it !!!!
www.bubbasignition.com
[email protected]
BUBBAS IGNITION is offline   Reply With Quote
Old 07-26-2016, 08:02 PM   #5
CP
CP's Avatar
thank you BuBBA..
