Old 07-24-2016, 11:27 AM   #1
biggieou
Default Points and timing help
I'm trying to replace the points and condenser and set the timing on my sport coupe. I replaced the points and condenser, had it at TDC. My test light is getting nothing though on the breaker point arm though. Car won't start. Switched back to the old points and condenser and no light either. What the heck did I do?
1931 Model A Victoria
1950 Mercury 8
Member: MAFCA, MARC, Northern Ohio Model A Club
www.northernohiomodela.com
biggieou is offline   Reply With Quote
Old 07-24-2016, 11:31 AM   #2
Gary WA
Gary WA's Avatar
Default Re: Points and timing help
Key on when you test?
www.whidbeymodelaclub.com
Old 07-24-2016, 11:32 AM   #3
Kevin in NJ
First question is why did you feel the need to replace the points? They should only be replaced when something is bad.
Now to your problem.
A test light will not show a light if the there is a short before the arm.
You need to trace the voltage from the lower plate to the upper.
Is there voltage at the end of the pop out cable?
Then follow the path through to the upper plate.
Kevin in NJ is offline   Reply With Quote
Old 07-24-2016, 11:37 AM   #4
biggieou
Key was on. The car had a miss and I have not changed the points and condenser, so I had no idea how many miles on them. I have voltage on the passenger side of the coil (although it's with and without the key on)
1950 Mercury 8
Old 07-24-2016, 11:37 AM   #5
Patrick L.
Patrick L.'s Avatar
Just start tracking back for voltage and find out where you're losing it. You'll only have it while the point arm is held open and not grounding.
This is a common subject so there is more info than you'll care to read in 'search'. And you won't have to search very far.
Old 07-24-2016, 12:02 PM   #6
biggieou
I'm not sure I know what you mean. How do I check lower and upper plates?
1950 Mercury 8
Old 07-24-2016, 12:41 PM   #7
Mitch//pa
Since this happened since you changed the points and condenser make sure the wire going to the top plate and the flag terminal is not grounding...did you unscrew the armored cable ?? Maybe it's put back in to far... More detailed info is always helpful... Such as what was removed,,, what style points do you have,,, wired or wireless plate,,,,with key off you should have voltage to both sides of the coil.... More info please
Old 07-24-2016, 12:55 PM   #8
Patrick L.
Patrick L.'s Avatar
As mentioned, it sounds as though you just have a primary connection/wire that is grounded and shouldn't be.
Just start looking for voltage and where it stops. Primary voltage should go completely thru to the moveable point arm [ if held open]. When the points are closed, no voltage should be present at them.
Its common for one of the connectors/fasteners to be contacting ground.
Old 07-24-2016, 01:23 PM   #9
biggieou
I did not mess with the armored wire. I simply (or not do simply) replaced the points and condenser. I have no idea what a wireless plate means, so I've attached this pic. Points and condenser are from Snyder's.
1950 Mercury 8
Old 07-24-2016, 01:31 PM   #10
biggieou
Here are a couple more pics
1950 Mercury 8
Old 07-24-2016, 01:58 PM   #11
Hook
Hook's Avatar
You have a modern style points set up with the wireless plate. That L shaped copper piece has to make contact with the lower plate to get voltage to the points. Loosen the nut and rotate the L shaped piece so it points down. Be careful not to let it touch either side of the upper plate or it will be grounded.
1930 Pickup in Prior Lake, MN
Hook is offline   Reply With Quote
Old 07-24-2016, 02:05 PM   #12
Mitch//pa
Do yourself a favor and get rid of the wireless lower plate set up....
That may have been causing your driveability issues to begin with
Old 07-24-2016, 02:07 PM   #13
biggieou
Ahhhhhh! Perfect! Thank you hook!
1950 Mercury 8
Old 07-24-2016, 02:54 PM   #14
Patrick L.
Patrick L.'s Avatar
Yep.
I don't a problem with the modern plate as long as quality points/condenser is used and it isn't wireless. The wireless ones are a PITA.
Old 07-24-2016, 03:03 PM   #15
Mitch//pa
It seems you also have an issue with your advance /retard Rod as its bent.. This can affect setting the timing correctly and overall drivability.
If you have any side play in the distributor shaft that will fluctuate your point gap
A simple picture is worth a thousand words...
Old 07-24-2016, 03:12 PM   #16
Tom Wesenberg
Tom Wesenberg's Avatar
Also get rid of the rust on the points cam and keep it lubricated.
Old 07-24-2016, 04:37 PM   #17
Keith True
Keith True's Avatar
That wireless plate setup is not one of my favorite things,but I keep after a couple of them for guys that have them.They look kind of chintzy,but if set up right they seem to stay working.That L shaped piece that you have on wrong fits very close to other parts that are grounds.You really need to get a good look at it and understand how it works.You have to get juice to that point arm without grounding it anywhere.I had one apart last spring,the owner had put a set of points in it and it wouldn't start.All I really had to do was rotate that L shaped arm about 1/16 of a turn and it was OK.He had it touching something when he tightened the nut on the points.After all the years and miles on it I figured it had arced out and finally given up,but when I took it apart it still looked like new.
Keith True is offline   Reply With Quote
Old 07-24-2016, 05:43 PM   #18
biggieou
Yep, once I knew it had to touch, I rotated it down and got it bolted without touching the top plate. Car fired right up then!
1950 Mercury 8
Old 07-24-2016, 07:55 PM   #19
tbirdtbird
I second #17.
The dizzy points cam is very dry, and will wear the rubbing block of the moveable points arm very quickly. You need dizzy cam lubricant, or a small packet of silicone brake lube you can get from your FLAPS (friendly local auto parts store). wipe a thin film on the cam, and paste a little dab on the side of the rubbing block on the counterclockwise side
'31 180A
tbirdtbird is offline   Reply With Quote
Old 07-24-2016, 08:36 PM   #20
Hook
Hook's Avatar
Glad you got the problem fixed and the car running. Others are correct in that you need to get some lube on the points rubbing block. I recently converted from the original points set up to the modern points set up because I couldn't find any "new" points that last. The rubbing block, with lube and a Stipe distributor cam, would wear so fast that the points would need adjusting every 80 to 100 miles. I tried our vendors and the parts houses, and couldn't find any that would last or align properly.
So I changed to the "modern" points, and went with the wireless "new and improved" version. The "L" shaped piece you had trouble with has been improved to help eliminate the problem with "grounding" that the old piece like you have. I guess I'll see if that was the problem folks had, but it has to be better than setting the points every 80 miles.
I'd get the lube and see what happens, making sure the L shaped piece doesn't contact any ground.
