Old 07-23-2016, 08:25 PM   #1
Afordman31
Afordman31's Avatar
Default Spark advance hi compression head
If the spark lever is in the down position, is that 0 degree and all the way up 40 degrees, or the other way around.
I have a new Snyder's 6.1 head installed and my directions say to run at 28 degrees. So is that a little past center toward retard or a little past center toward advance? Thanks
Afordman31 is offline   Reply With Quote
Old 07-23-2016, 08:30 PM   #2
Mitch//pa
Default Re: Spark advance hi compression head
0 is up
You may find that you may not have to go past center or even stay before center..
You can find your exact 28 deg using an adjustable timing light
Old 07-23-2016, 08:49 PM   #3
tbirdtbird
let us know how you make out
'31 180A
tbirdtbird is offline   Reply With Quote
Old 07-23-2016, 10:26 PM   #4
Mike V. Florida
Mike V. Florida's Avatar
Location: Florida between Sarasota and TampaSouth Florida
Pick a speed, bring the car up to that speed and start to slowly lower the lever. You will notice the engine picking up speed . At some point the engine will no longer speed up. raise the lever one notch. This is the "best" advance for that speed.
Old 07-23-2016, 10:45 PM   #5
Bruce Adams
Bruce Adams's Avatar
I do it as Mike V stated and it works well having the engine tell you where it is happiest. Its interesting on a highway to be doing 55 and then raising OR lowering the spark lever and see it jump to 57 or 58 mph. I keep track of mine how that sweet spot falls into the pin stripe on my dash, but I still play with it when driving and bored on the highway.
Bruce Adams is offline   Reply With Quote
