Old 07-23-2016, 04:32 PM   #1
Tom Wesenberg
Tom Wesenberg's Avatar
Default Want Brighter Lites, What is this Gizmo?
While looking for some distributor parts I came across this gadget. It's about an inch high and about 2" by 4" at the mounting flange. It's too light to be a step up transformer. It was made in Denver, Colorado. I've never seen anything like it, and wonder how it works or was wired into the system. It has two short wires coming out that were cut off and have no terminals.
The only thing I can think of is it might be a low ohm resistor that is wired between battery voltage and the field windings to increase the generator output.
Interesting that it says for Ford cars. Since it seems to be an aftermarket thing that could be used for any car, why specify Fords?
Anyone have any information on it? Thanks
Old 07-23-2016, 04:50 PM   #2
Bob C
Default Re: Want Brighter Lites, What is this Gizmo?
If you take those two small screws out will the cover come off??
Bob
Old 07-23-2016, 05:07 PM   #3
V8COOPMAN
V8COOPMAN's Avatar
Here's one with three wires. I found some reference to cars with magnetos......like "Ts". DD
Click Links Below __
T5 W/TORQUE TUBE
Old 07-23-2016, 05:11 PM   #4
davehc
davehc's Avatar
Tom , Found this doing a Google search , seems it was used to increase the brightness of the head lights .
https://books.google.com/books?id=-D...20cars&f=false
davehc is offline   Reply With Quote
Old 07-23-2016, 05:38 PM   #5
Tom Wesenberg
Thanks Dave. So this gadget turns off one headlamp and lets all the magneto power go to the other headlight. Why they want to turn off the left headlight is a mystery, as it would be safer to light the left than the right.
Old 07-23-2016, 07:23 PM   #6
bunnyc
bunnyc's Avatar
Right side illuminates the edge of the road?
I see your point about the left side safer for cars approaching from the opposite direction.
bunnyc is offline   Reply With Quote
Old 07-23-2016, 10:31 PM   #7
Mike V. Florida
Mike V. Florida's Avatar
Location: Florida between Sarasota and TampaSouth Florida
"not recommended above speeds of 20 m.p.h."
Old 07-24-2016, 12:24 AM   #8
Tom Wesenberg
Probably because the magneto would put out too much power for just one lamp, and it would burn out.
Even running a 6 volt car on an 8 volt battery greatly shortens bulb life.
