Old 07-18-2016, 10:03 PM   #1
slowforty
Default 1940 tudor seat and 1941 tudor seat
Does anyone know if A 1940 Tudor Front seat and a 1941 Tudor front seat are the same??
slowforty is offline   Reply With Quote
Old 07-18-2016, 11:11 PM   #2
Flathead
Flathead's Avatar
Default Re: 1940 tudor seat and 1941 tudor seat
The 41 was a new body and frame, I would guess that the seat is different too, but I don't know for sure.
Flathead is offline   Reply With Quote
Old 07-19-2016, 06:44 AM   #3
skidmarks
skidmarks's Avatar
No its too wide. 37 to 40 is what will fit but between those years mounting brackets on the base changed. 39 or 40 is really what your easiest fit will be
skidmarks is offline   Reply With Quote
Old 07-19-2016, 11:51 AM   #4
Seth Swoboda
Seth Swoboda's Avatar
Keep in mind that the bodies were wider in '41. I believe '41 is the first year for the running boards inside the doors rather than outside as prior. 1940 first year for column shift last year for exterior running boards.
Seth Swoboda is offline   Reply With Quote
Old 07-19-2016, 04:11 PM   #5
slowforty
OK.
Thank You
Roger
