Old 07-16-2016, 09:20 PM   #1
Lawrie
Lawrie's Avatar
Default main bearing drama
I,m assembling a C69a engine,I ordered the main bearings for 1939-1948, the rear bearings won't fit into the block ,they are too narrow on the id of the rear main thrusts,(D dimension) the overall width is right(C dimension) where they fit into the crankshaft,also they only have a narrow locating tag,where as in the block it is a wide style.
looking at my stuff it looks like the bearings I got are for an 8Ba.
I think I need the 81a-6331 style.
Am I right
Lawrie
Lawrie is offline   Reply With Quote
Old 07-16-2016, 10:12 PM   #2
Ronnie
Ronnie's Avatar
Default Re: main bearing drama
Turn the bearing over is there a part # on it?
R
Ronnie is offline   Reply With Quote
Old 07-16-2016, 10:14 PM   #3
Lawrie
Lawrie's Avatar
yes King MB3351S1-020
Old 07-16-2016, 10:55 PM   #4
Brian
Brian's Avatar
You are right; 81A prefix.
Unfortunately, two half wits don't make a whole wit!
Brian is offline   Reply With Quote
Old 07-17-2016, 06:17 AM   #5
GOSFAST
GOSFAST's Avatar
Am I right
Lawrie
Hi Lawrie, if there's anyone in your area with a decent lathe you will be able to use that set. Not all that difficult for a good machinist?
You need to remove .015"/.016" from the backsides of the thrust surfaces on both shells. We've done a number of these over the years when the early sets weren't available/out-of-stock.
Thanks, Gary in N.Y.
P.S. Lawrie, on a side note here, this shot may help with another question you asked. These are nice pieces (stainless) considering the cost, just put another large number on the shelf.
GOSFAST is offline   Reply With Quote
Old 07-17-2016, 06:33 AM   #6
Walt Dupont--Me.
Walt Dupont--Me.'s Avatar
Hey lawrie, I'm not familiar C69A but I'm sure you need rear bearing from the what we call 59AB the center and front bear are the came. accually 39-53 have the same center and front bearting, Walt
Walt Dupont--Me. is offline   Reply With Quote
Old 07-17-2016, 07:06 AM   #7
Ronnie
Ronnie's Avatar
What Walt said^^^
R
Old 07-18-2016, 08:54 AM   #8
Juergen
I had the same problem and fordbarners came to my rescue. Sealed power sells the 39-48 mains under their number 533M which has a generic number MS 108M while their bearings for a 49-53 are numbered 646M which has a generic number MS 352A. The selling vendor claimed the MS 352a would fit all years. Also barner "barnfind08" had the 39-48 rear main that I needed and would sell me only the rear main.
Juergen is offline   Reply With Quote
Old 07-19-2016, 12:11 PM   #9
rotorwrench
rotorwrench's Avatar
The Canadian Windsor plant started in with the insert rod bearings a good bit before the 8BA (C8BA) came out. This does make for some interesting combinations since the Canadian C69A has a bit of both eras for bearings.
Old 07-19-2016, 12:55 PM   #10
Mart
Mart's Avatar
FWIW the French motors use 59A type main bearings, not 8BA as I first thought. That was an expensive mistake.
Mart.
