Old 07-16-2016, 04:39 PM   #1
chucksue
Default rear axle seals
Just some information. I am rebuilding a 40 Ford rear end. I found a seal that will press from the outside into the axle housing and seal in the rear end oil. It is a SKF 11050. I made the tool to drive it in.
chucksue is offline   Reply With Quote
Old 07-16-2016, 05:59 PM   #2
texas webb
Default Re: rear axle seals
Noted,thanks.
texas webb is offline   Reply With Quote
Old 07-16-2016, 08:59 PM   #3
JM 35 Sedan
JM 35 Sedan's Avatar
Found this on epay.
http://www.ebay.com/itm/SKF-11050-Oi...-/271988211109
Is this like the ones you are using?
I found some slightly different seals that will basically do the same thing. Unfortunately, I don't know the manufacturer's name nor their part number.
John
Old 07-17-2016, 03:48 PM   #4
chucksue
No the ones I found are without a flange. When you drive them in there is no way to remove them without separating the rear housing. The good thing there is enough room to install several of these. I put two in each side.
