Old 07-11-2016, 10:09 PM   #1
1932chevy
Default Verifying Banjo Ratio
With the axle on the ground, what would be the correct method in verifying the gear ratio by means of pinion revolution and drum revolution. Do I have to lock up one wheel? Let's say I didn't lock up one wheel and got 2.25 revolutions per drum rev can anyone tell me if its a 4:11 or 3:78?
Any one have a 3:78 rear that they could spin and help me out?
1932chevy is offline   Reply With Quote
Old 07-11-2016, 10:17 PM   #2
slowforty
Default Re: Verifying Banjo Ratio
Near impossible with a torque tube.
slowforty is offline   Reply With Quote
Old 07-11-2016, 10:29 PM   #3
1932chevy
Sorry for not clarifying, the rear is of the car. No torque tube.
Old 07-11-2016, 10:34 PM   #4
texas webb
The bottom rib under pinion has numbers stamped-example 9-34 divide is 3.777777.
texas webb is offline   Reply With Quote
Old 07-11-2016, 10:58 PM   #5
1932chevy
I'm Trying to verify that the gears are original to the housing
Old 07-11-2016, 11:13 PM   #6
Andy
The way to do it is lock one wheel from turning and count the turns of the pinion to make the free wheel turn two times. If you did it this way but only made the free wheel turn once and got 2.25 turns, you have an about 4.50 ratio.
Andy is offline   Reply With Quote
Old 07-11-2016, 11:21 PM   #7
bbrocksr
Put in high gear, jack up one wheel and mark it now turn the engine with a wrench or crank and count the revolutions of the crankshaft until the wheel makes two complete revolutions. Three and three quarter turns would be 3.78.
It's a lot easier on a open drive shaft.
Bill
bbrocksr is offline   Reply With Quote
Old 07-11-2016, 11:27 PM   #8
JM 35 Sedan
JM 35 Sedan's Avatar
Here is an old post that has a slightly different approch on how to do this......
http://www.fordbarn.com/forum/showth...rear+end+ratio
John
Old 07-12-2016, 12:13 AM   #9
1932chevy
Andy I didn't lock the opposing wheel, stupid me. Well worst case, I'd have to spend 300+ for a new 3:78 gear set
Old 07-12-2016, 06:47 AM   #10
jimTN
Pull the filler plug, mark end of one of the ring gear teeth with either paint or chaulk, turn a wheel with the other wheel down and trans. in neutral and count teeth on ring gear.
jimTN is offline   Reply With Quote
Old 07-18-2016, 11:17 PM   #11
1932chevy
This turned out to be the best option for me, thanks.
Old 07-19-2016, 06:33 AM   #12
theHIGHLANDER
And the ratio is...? Just curious
theHIGHLANDER is offline   Reply With Quote
