Old 07-09-2016, 03:20 PM   #1
jkflathead
Default Removing a '35, 3 window body from the frame
Has anybody had the experience of removing a 1935 Ford 3 window body from the frame? How much does it weigh? Can six guys do it? Three on each side. Remove the doors. Thanks. jk
jkflathead is offline   Reply With Quote
Old 07-09-2016, 03:24 PM   #2
V8COOPMAN
V8COOPMAN's Avatar
Default Re: Removing a '35, 3 window body from the frame
Four guys can do it easily......two in a pinch. Six guys is way too easy! Using a cherry picker is mo-better than anything. DD
Click Links Below __
T5 W/TORQUE TUBE
Old 07-09-2016, 04:02 PM   #3
weemark
As above, 4 people can do it without any real struggle, with 6 people it would be easy. You Don't need to take the doors off.
weemark is offline   Reply With Quote
Old 07-09-2016, 04:03 PM   #4
jkflathead
Thanks. How much does the body weigh approximately? jk
Old 07-09-2016, 04:12 PM   #5
weemark
The whole car would be about 1200kg, no idea what a body on its own would weigh, I've never weighed any of my cars.
Old 07-09-2016, 04:41 PM   #6
JSeery
JSeery's Avatar
I can move a 34 coupe body by myself, so not that much. Couple of hundred pounds I would guess.
Old 07-09-2016, 08:53 PM   #7
Lawson Cox
Lawson Cox's Avatar
I removed a 36 club cab off the frame by myself, and I'm 5'8 and weigh 135 lbs.
Old 07-09-2016, 09:48 PM   #8
my4dv8
I have removed and replace a couple of mid 30s ford coupe bodies on my own . Just take your time engine crane one end and the other end an endless chain attached to the rafters.
The hardest thing is getting it high enough to allow the body 2x4 supports on oil drums to clear the tyres to roll the chassis out.
my4dv8 is offline   Reply With Quote
Old 07-10-2016, 06:55 AM   #9
d.conrad
d.conrad's Avatar
Here's how I did it. With my lift and a cherry picker and me.
d.conrad is offline   Reply With Quote
Old 07-10-2016, 11:14 AM   #10
34pickup
34pickup's Avatar
You can buy a couple of those cheap Harbor Freight cherry pickers if you don't have one and use one on each end.
Matt 24:36-41
34pickup is offline   Reply With Quote
Old 07-10-2016, 12:00 PM   #11
waterboychuck
waterboychuck's Avatar
When I removed my body I built a frame so I could move the body around easily.
The sign of a good craftsman is how well they cover up their mistakes.
waterboychuck is offline   Reply With Quote
Old 07-10-2016, 12:19 PM   #12
V8COOPMAN
V8COOPMAN's Avatar
No reason to over-think this......ONE cherry picker can be used in many different ways. You can even use a couple of landscape timbers thru the front and rear window/door openings. Just make sure you lift from ABOVE the CG. DD
T5 W/TORQUE TUBE
Old 07-10-2016, 01:18 PM   #13
TagMan
This is how I lifted mine alone.................
TagMan is offline   Reply With Quote
Old 07-10-2016, 06:04 PM   #14
WRA
WRA's Avatar
Tagman, do you have a picture of how you attached it to the lift?
WRA is offline   Reply With Quote
Old 07-10-2016, 09:02 PM   #15
jkflathead
Thanks! You guys are amazing. I will keep you posted.
jk
Old 07-11-2016, 12:08 PM   #16
TagMan
WRA, here's a pic of the center section of the lifting beam. Not real pretty, but works well and was made out of parts I had laying around. The beam is a 4"x4"x6'.
I placed the piece of steel 2"x4" to allow the beam to pivot as the cherry picker is raised & lowered &and to have the body remain level, as well as to space out the side brackets and add rigidity.
The pivot is a 1/2"x5" hex head bolt.
The square tubing fits nicely into the cherry picker arm after the chain & hook are removed.
I've used this set-up on the '36 several times now and on a '46 Chevy pick-up cab, too. I can lift both of them alone with no problem.
Hope this answers your request, but if not, let me know and I'd be glad to tell you anything you'd like to know.
-Bob
Old 07-11-2016, 03:58 PM   #17
A bones
A bones's Avatar
Some times I wonder if those bare naked coupe bodies know just how pretty they are.
Enjoy yer day. Tom
Hate can't fix what it started.
A bones is offline   Reply With Quote
Old 07-18-2016, 05:22 AM   #18
WRA
WRA's Avatar
That is slick, thanks Tagman.
