Old 07-08-2016, 06:01 PM   #1
fordman
Default '40 coupe
just discovered no volts to light switch ; replaced fuse to light switch .
no lights head, tail , or parking, no smoke
engine starts and runs.
what do you suggest I should check ?
thanks
fordman
fordman is offline   Reply With Quote
Old 07-08-2016, 06:08 PM   #2
30-9
Default Re: '40 coupe
Volt meter and trace back to see where you do have volts.
Thanks - 30-9
1939, 1940
30-9 is offline   Reply With Quote
Old 07-08-2016, 07:02 PM   #3
JSeery
JSeery's Avatar
Did you check the fuse or just replace it? Was it blown?
Old 07-08-2016, 08:37 PM   #4
fordman
yep. the fuse was blown so I replaced it.
Old 07-08-2016, 08:51 PM   #5
Ken/Alabama
Ken/Alabama's Avatar
Didn't know a 40 had a fuse.
Ken/Alabama is offline   Reply With Quote
Old 07-08-2016, 09:07 PM   #6
JSeery
JSeery's Avatar
Ken is correct, the 40 should have a circuit breaker not a fuse. It may have been modified somewhere along the way. If it blew a fuse once you may need to determine why.
Old 07-08-2016, 10:17 PM   #7
fordman
could find original light switch that looked original so I replaced with switch that had a built-in fuse that I installed under dash .
fordman, "kinda"
Old 07-08-2016, 10:48 PM   #8
JSeery
JSeery's Avatar
Then have you checked the CB to see if you have power out to the lighting switch?
