Old 06-03-2016, 02:41 PM   #1
farmerdick
farmerdick's Avatar
Default smaller tires and wheels
I have 3:54 gears in rear housing 19" wheels and stock 4cyl in 1930. I want to run 16" wheels on front and 17" on rear. What would I expect for rpm`s, steering, engine problems or anything else with this set up. Thanks.
Farmerdick
farmerdick is offline   Reply With Quote
Old 06-03-2016, 02:47 PM   #2
CarlG
CarlG's Avatar
Default Re: smaller tires and wheels
Kinda depends on what tire you are putting on the 16s & 17s
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 06-03-2016, 02:54 PM   #3
C26Pinelake
why do you want to make that change? Wayne
C26Pinelake is offline   Reply With Quote
Old 06-03-2016, 03:07 PM   #4
farmerdick
farmerdick's Avatar
I`am not sure as yet. Any suggestions would be helpful. Most likely radials. Bias ply would be ok. What do you think?
Old 06-03-2016, 03:35 PM   #5
Bob/Kansas City
Bob/Kansas City's Avatar
The aspect ratio of the tire should be taken into account along with rim diameter as both will affect your final gearing. A taller sidewall vs. a shorter sidewall will make a difference.
Bob/Kansas City is offline   Reply With Quote
Old 06-03-2016, 03:39 PM   #6
Safewiz
Safewiz's Avatar
Smaller tire equals higher rpm and less top end speed
Safewiz is offline   Reply With Quote
Old 06-03-2016, 04:04 PM   #7
CarlG
CarlG's Avatar
Whatever you get, I would try to stay as close to the same height as your 19's are.
Alaskan A's
Old 06-03-2016, 07:44 PM   #8
DougVieyra
DougVieyra's Avatar
I saw a TCM movie today - 1943 vintage, with Judy Garland and Micky Rooney. I think it was called "Girl Crazy".
Prominent in the movie was a (11 years old at the time the movie was made) 1932 Ford Phaeton. It was interesting (perhaps I should say, 'odd') to note that the wheels on the '32 (nominally stock 18") were - 21" Ford Steel-Spoked wheels of 1928-'29 !
DougVieyra is offline   Reply With Quote
Old 06-03-2016, 10:00 PM   #9
eagle
eagle's Avatar
I think the only "problem" you will have is that it will look funny. Should work just fine otherwise.
"There are some that can destroy an anvil with a teaspoon and shouldn't be allowed to touch anything resembling a tool."
eagle is offline   Reply With Quote
Old 06-04-2016, 05:34 AM   #10
updraught
updraught's Avatar
Aren't 16 rims 4 inches wide and 17 inch 3 inches wide?
http://www.jalopyjournal.com/forum/t...l-tech.113082/
updraught is offline   Reply With Quote
Old 06-05-2016, 11:24 AM   #11
captndan
captndan's Avatar
At the car show yesterday there were a few A's with smaller than stock wheels and tires. The cars were beautifully done but just didn't look right. I'll stick with the 19's until I put the Cummins diesel in it. (30 coupe)
captndan is offline   Reply With Quote
Old 06-05-2016, 12:06 PM   #12
majohnson00
I'm with updraught, Put the 16" on the back, 17" on the front and find the correct tire height for each. Same caps fit both, can't really tell the difference in the rim size.
majohnson00 is offline   Reply With Quote
Old 06-05-2016, 02:36 PM   #13
C26Pinelake
Get used to people laughing at your car! Wayne
Old 06-05-2016, 10:28 PM   #14
1929
I have 16s, handles and brakes much better.
1929 is offline   Reply With Quote
